Originally Posted by sconly
should probably have your dealer do it, I dont mean any offense but if you can't figure it out on your own...
there is two bolts that hold each side with a series of washers, remove the seat because two of the bolts are under the seat, the other two are upside down going in from the underside.
I appreciate it, I was asking because I wanted to see if there were any complications and what I would need to do this. Sometimes there are postings where the person says that the threads stripped and they needed vice grips. I just wanted to ensure that I'm ready so there are no surprises. Much appreciated that you responded so quickly. I also wanted to know if there was a kit I needed or I could mod something for the plate.
