New member...new Hyper 796 - Ducati.ms - The Ultimate Ducati Forum
Motorcycle.com
Old May 1st, 2011, 12:32 am   #1 (permalink)
I picked up a new 2010 matte black Hyper 796 today. Only dumb question i can think of at the moment is...why does that red light continually flash on the gauge cluster? I had a Multi 1000 S for a short period ,...and that one had a yellow light that flashed continually. I did read the new Hyper owners handbook...and there is no explaination of why that light flashes. Does that light flashing prohibit a Deltran battery tender from fully charging the battery? On my Multi...it would charge....but the light on the Battery tender would never turn green. Will the Hyper do the same thing?
Seven9Six is offline   Reply With Quote
Old May 1st, 2011, 1:02 am   #2 (permalink)
Gilly's Avatar
Images: 17
Congrats on the bike...
The bike has an Immobilizer integrated into the dash, ignition key and ECU. Sort of make it harder to just hot wire the bike. Or it makes asshats who steal very frustrated so they either know it and pass on the Duc, or don't know it and just plain do stupid stuff that dont work.
The blinking light shows you and the asshat that your protected. If let to sit, the blinking will stop after a while. Has nothing to do with your trickle charger. That is another story if you were not able to achieve a green light on the tender.
If you have your owners manual, read the section on the Immobilizer, make sure you have your secret code in your wallet, should you ever need it. Might need to copy the instructions for entering the code if you ever have an Immobilizer issue. I dont hear of many of them... unless others care to chime in on that.
"Oh My!" thread link... FFS!
Old May 1st, 2011, 9:02 am   #3 (permalink)
johnnymotocros's Avatar
CONGRATS !!!
The flashing red light is a Warning that the bike should be inmediately started and ridden or it will self destruct. If you don`t want this to happen, find the two neon-red-electrosolar wires that run under the tank and cut them, this wires supply neutrons to the igniter that`s installed inside the tank for blowing the gas after 1 hour of inactivity.
Now, Stop writing silly things and GO RIDING and put some miles on that awesome machine you just got before it goes BOOMM !!!!!!
08 Hyper
05 KLR650
99 Monster 750
04 KLR650
01 Ducati 900SS
85 Suzuki 700ES
89 Ninja 250
87 Honda Rebel 450
86 Honda Interceptor 500
84 Yamaha TriZ ( street legal )
77 Yamaha Enduro 400
73 Suzuki TC100
*various dirt and road bikes not street legal
johnnymotocros is offline   Reply With Quote
Old May 1st, 2011, 10:25 am   #4 (permalink)
Originally Posted by Gilly View Post
The blinking light shows you and the asshat that your protected. If you have your owners manual, read the section on the Immobilizer, make sure you have your secret code in your wallet, should you ever need it. Might need to copy the instructions for entering the code if you ever have an Immobilizer issue. I dont hear of many of them... unless others care to chime in on that.
Thanks.
Old May 1st, 2011, 11:20 pm   #5 (permalink)
Decreasing Dave's Avatar
Images: 14
If it's doing that while your riding, then it's the rev limiter light and you should try shifting to any one of the other 5 gears for it to stop, at least temporarily.....
If you are parked, it's the immobilizer like they said.
Just wanted to cover all of the bases for the new guy.
Dave
My DOC Welcome Kit
Dave Yeski
CCS Southwest Expert #99
(apparently retired....)
2008 Hypermotard S Black!!!!
2006 Yamaha YZ450F Supermoto
Old May 1st, 2011, 11:27 pm   #6 (permalink)
Extended Member
CAlexio's Avatar
it's the light that turns on to remind you the bike is in reverse gear. Make sure you shift out of reverse before taking off in the am
Old May 2nd, 2011, 12:13 am   #7 (permalink)
Dave
Thanks Dave.....i'm an old roadracer..and since this bike hasn't seen 7k yet...it's not the rev limiter. Still...no one has told me why the light is on sometimes WHILE PARKED....and other times it's not on WHILE PARKED.
It's no biggie...i'm just curious what triggers the light. I know it's the immobilizer light...but i can't figure out the timeing.
Old May 2nd, 2011, 1:20 am   #8 (permalink)
Images: 14
After you shut off the key, the light will blink for a period of time. When that time expires, the light stops, until you turn on and off the key again and then the timer starts all over again.
When I go to MotoGP, I will go to the bike and cycle the key just before I shut off the lights and go to bed. If someone is "casing" the bike, "lights out" is the best time to steal it as they have a longer timeline before it is discovered missing.
Hopefully, the light is enough of a deterant, if not, the cable and lock between the bikes should help.
Dave
My DOC Welcome Kit
Dave Yeski
Old May 2nd, 2011, 10:34 am   #9 (permalink)
"Still...no one has told me why the light is on sometimes WHILE PARKED....and other times it's not on WHILE PARKED".
Seven9six, in case you have not counted well, in order for the red light to be a "blinker", it has to be 1/2 time on, and 1/2 time off !!!!!!!!
If you stare at it for more than two seconds, you will see what I mean. And remember, cut the two neon orange wires, I just spoke with DNA, and No, it will not void the warranty, as long as the bike has not blown up yet.
08 Hyper
05 KLR650
99 Monster 750
04 KLR650
01 Ducati 900SS
85 Suzuki 700ES
89 Ninja 250
87 Honda Rebel 450
73 Suzuki TC100
Old May 2nd, 2011, 2:22 pm   #10 (permalink)
el tardo's Avatar
when i had my bike in my living room for a couple of days while doing stuff to it the light stays on for i think 12hours or 24 hours dont remember.its just a dummy alarm light. its also a led to the drain is nothing to hurt the battery
2010 black 796
dont make me badge you!!
New member new Hyper SirNoseJr Welcome and Introduction 0 Mar 21st, 2011 1:33 pm
New Bay Area Hyper Evo SP member Roadsurfer Welcome and Introduction 1 Aug 18th, 2010 9:51 pm
New Member, just picked up a Hyper 1100s! firstarsbrnwhite Welcome and Introduction 1 May 11th, 2010 9:48 am
new hyper member performerk Welcome and Introduction 1 Apr 20th, 2010 4:25 pm
New Hyper member 1day Welcome and Introduction 0 Feb 16th, 2010 2:35 pm
