Blown bulb/fuse ...help! - Ducati.ms - The Ultimate Ducati Forum
Motorcycle.comGraves MotorsportsSportbikeTrackGearMotorcycle.com Classifieds!
Old Apr 27th, 2011, 12:00 pm   #1 (permalink)
So, twice in the past week my '10 796 has blown both the license plate bulb and the 15a "LIGHTS" fuse, causing the headlight and taillight to go out. All other bulbs and fuses are ok. The filament in the plate bulb is super thin, so I'm not surprised it's breaking, but would that then cause the fuse to blow?
The bike hasn't had front turn signals since last year but I didn't see this problem until I recently disassembled everything for paint. The bike went back together fine and everything worked as before until this issue came up.
Anyone seen this problem before? Any theories?
LIDuke is offline   Reply With Quote
Old Apr 27th, 2011, 12:38 pm   #2 (permalink)
Home of vortex tuning
CDONA's Avatar
Because it was just reassembled, I would look for a pinched wire/wiring loom around the lights causing the blown fuses.
Old Apr 27th, 2011, 12:53 pm   #3 (permalink)
I had the same problem.. Mine was a pinched license plate light wire because of the way I did the tidy tail.. Bought an LED tag light and rewired it. 3 LED TAG LIGHT License Plate Universal GSXR R1 R6 CBR | eBay
Then I mounted the plate by the battery box and attached the light.
nitsuj8686 is offline   Reply With Quote
Old Apr 27th, 2011, 1:05 pm   #4 (permalink)
Extended Member
CAlexio's Avatar
EXACTLY! the screws that go into the license plate light serve as a ground, if these aren't put back together properly then it causes this issue. I had the same thing happen with both front and rear headlights not coming on.
Old Apr 27th, 2011, 1:31 pm   #5 (permalink)
Great! Thanks for the quick responses guys - at least now I have a few leads to look into. The bit about the ground is interesting, I didn't know that. The light is mounted to a custom made stainless plate bracket which is bolted to the subframe right behind the battery, so I could easily run a short ground wire to it. Thanks again, I'll post again when its fixed to let you know what the culprit was.
Old May 2nd, 2011, 10:10 am   #6 (permalink)
FIXED!
Cal you were almost right - the ground lead is in contact with the mounting studs but they should NOT be grounded to anything. The relocation bracket was providing a path to ground through the subframe due to it being stainless (as opposed to the factory plastic one), so I put some nylon grommets in there and that did the trick. Thanks again folks
Old May 2nd, 2011, 10:57 am   #7 (permalink)
johnnymotocros's Avatar
Duke, make shure you get good fuses before you leave the store. The other day I bought a few and when I checked them with the omg-meter they were ALL shorted from the factory. Too bad. I went back to the store and they gave me one was not shorted ( for free, they were really nice !!! ). The only problem is that my lights still do not work with the new fuse.
Now I don`t know what to do.
08 Hyper
05 KLR650
99 Monster 750
04 KLR650
01 Ducati 900SS
85 Suzuki 700ES
89 Ninja 250
87 Honda Rebel 450
86 Honda Interceptor 500
84 Yamaha TriZ ( street legal )
77 Yamaha Enduro 400
73 Suzuki TC100
*various dirt and road bikes not street legal
johnnymotocros is offline   Reply With Quote
Blown fuse?-need help rixster StreetFighter 13 Apr 22nd, 2012 3:05 pm
Blown 5 Amp Fuse laszlost Superbikes 10 Oct 5th, 2009 11:10 am
Blown Fuse MY45 HyperMotard 7 Sep 9th, 2008 7:12 am
Blown 5amp fuse Dave748s Superbikes 5 Jan 10th, 2008 12:02 am
748 blown fuse dunlop0_1 Superbikes 7 May 22nd, 2006 3:52 am
