Apr 27th, 2011, 7:22 am
chain sprocket
it s time to change
your option..?
Apr 27th, 2011, 9:50 am
I use a 15/43 (stock is 15/42) I find that now I can hit redline in 6th, and still have freeway legs. IMHO I would not go to a 14t front due to possible chain concerns with a modded motor.
My MODII is a highly modified engine, if my engine was stock I might use a 15/44 combo.
I also us a 520 set-up with a Supersprox sprocket, it has outer steel teeth and a alminum center. Just use a high quality chain. Aloha Alex
Apr 27th, 2011, 5:07 pm
I'm running 14/42, an it's great. Short but great.
Got my ne chain and rear 42 Supersprox from JCPakbikes. Poorest website design ever but great great guy to deal with (and great prices)
Apr 27th, 2011, 5:46 pm
15/45 supersprox stealth 525. not too low, need 2 more links in chain.
2009 Hypermotard S Black
Apr 28th, 2011, 9:55 pm
wow I am about to do the same thing on my 1100 hyper and I am actually thinking going down one tooth on the rear to give it a little lower RPM on the highway at 65 - 75 mph. It can wheelie no prob 1st and 2nd so I do not understand why you guys would go up one in the rear? Why do u need more low end and does it run that much quicker going down one in the rear?
I have 2-1-2 Termi with Zard header.
Thanks
08 Ducati Hyper 1100
06 Honda CRF-88cc SM
07 Husky SMR 510 (sold)
05 Suzuki GSXR 1000 (sold)
06 Suzuki DRZ 400sm (sold)
04 Suzuki GSXR 750 (sold)
01 Yamaha R6 CLE (sold)
Apr 28th, 2011, 11:44 pm
It's not necessarily about the low end. For some it is about the top end.
Currently, stock or even with the mods that you have, you probably cannot hit redline (flashy light thingy) in 6th gear, without a tailwind and a lot of space. Dropping 1 tooth on the front, or my personal favorite, bumping 1 or 2 teeth up on the rear will allow you to run your bike to redline (flashy light thingy) in 6th, thereby netting you an actual higher top speed if done moderately.
Plus it wheelies easier in the lower gears!!!
Dave
My DOC Welcome Kit
Dave Yeski
CCS Southwest Expert #99
(apparently retired....  )
2008 Hypermotard S Black!!!!
2006 Yamaha YZ450F Supermoto
Apr 29th, 2011, 5:48 am
Do you need a larger chain if you go up a tooth on the rear?
Apr 29th, 2011, 9:01 am
thanks a lot
Apr 29th, 2011, 9:19 am
No just adjust her. Aloha Alex
Apr 29th, 2011, 12:05 pm
What about 2 teeth up in the rear, do you think can get away with adjusting?
