Which vdst kit? - Ducati.ms - The Ultimate Ducati Forum
Old Apr 25th, 2011, 10:46 pm   #1 (permalink)
Which vdst kit?
I have a 2010 evo sp and since my closest dealer is about 450km away I will be getting the first service done at the local harley dealer so I will need a vdst to reset the service light myself. Problem is I have no clue as to which ecu I have and most vdst kits I've looked at are specific to certain ecu's. Can anyone let me know the exact kit I need? Thanks
jenner is offline   Reply With Quote
Old Apr 25th, 2011, 11:37 pm   #2 (permalink)
Decreasing Dave's Avatar
Images: 14
You don't need one to reset your ECU, it resets everytime you turn on your key. You have the Siemens, the VDSTS' are for MM ECUs.
Dave
My DOC Welcome Kit
Dave Yeski
CCS Southwest Expert #99
(apparently retired....)
2008 Hypermotard S Black!!!!
2006 Yamaha YZ450F Supermoto
Old Apr 26th, 2011, 7:06 pm   #3 (permalink)
So only the dealer can reset the service light on the 2010?
Old Apr 27th, 2011, 7:02 am   #4 (permalink)
Can anyone give me a definite answer on resetting the service light on a 2010 sp? The manual states that the light will stay on until the dealer resets it but I would think there has to be a way to do this without going to the dealer.
Old Apr 27th, 2011, 7:32 am   #5 (permalink)
PKM
Pretty sure only dealer can reset wrench. On earlier models, which require VDST software to reset TPS, you can also use the VDST to reset maintenance wrench.
PKM is offline   Reply With Quote
Old Apr 27th, 2011, 7:27 pm   #6 (permalink)
Thanks for the info. Hopefully someone comes up with something that can interface with the new ecu in the near future
Old Apr 28th, 2011, 1:19 am   #7 (permalink)
Images: 14
I just ignored my "little wrench" for about a thousand miles before I rented a VDSTS from a forum member. It will be popping up here again soon enough when I hit the 7500 mile mark. I may just have to ignor it then too.
Dave
My DOC Welcome Kit
Dave Yeski
Old Jun 9th, 2011, 11:53 am   #8 (permalink)
Bob92's Avatar
This diagnostic system is free, you have to buy the cables though. It is frankly amazing. ducatidiag :: Connexion I got cables off amazon for about $40 total. (Diagnostic cable and adaptor for Ducati.) Also has a system for the older ECU's including P8.
Allowed me to reset TPS and adjust CO, my bike runs great now.
Also clears the wrench.
You are what you practice to be.
'98 M750
'99 ST4
'00 748R (almost RS, track only)
'08 1098 (track only)
Bob92 is offline   Reply With Quote
Old Jun 9th, 2011, 1:51 pm   #9 (permalink)
Images: 14
Whoa!! How does this work and do you have the part numbers for the necessary cables for the Hyper??
Thanks,
Dave
My DOC Welcome Kit
Dave Yeski
Old Jun 9th, 2011, 2:02 pm   #10 (permalink)
corvus's Avatar
Thanks
Do you have a link to Amazon for the proper cable.
Thanks
corvus is offline   Reply With Quote
Vdst Chuckracer Sport Touring 12 May 22nd, 2010 8:04 am
Re: Vdst MAZDuc Sport Touring 2 Mar 4th, 2010 8:17 am
Vdst RockingM Sport Touring 0 Mar 27th, 2009 7:20 pm
my first VDST run DesmoDuke Superbikes 2 Nov 21st, 2008 9:44 am
Vdst nemesisHM HyperMotard 3 Sep 17th, 2008 10:43 pm
