Short and Hyper - Ducati.ms - The Ultimate Ducati Forum
Old Apr 24th, 2011, 5:23 pm   #1 (permalink)
ktrides2's Avatar
Short and Hyper
I have a new 796 and I needed to shave the seat and make adjustments because my feet are nearly 4" off the ground stock . Waiting on the gel insert I purchased for the seat, then I THINK I can ride it, its driving me crazy sitting in my garage!! I haven't even told all my riding friends about the new bike yet. Ugh.
We also adjusted the rear spring, I need to do something to the front, but thats hard on this bike.
Anyway, That is all. Thank you.
Oh, BTW... I did take it around the block with no seat cushion and my butt was bruised for days!
GirlRiders.net
2010 Ducati Hypermotard 796
2005 Suzuki GSXR 750
2003 Honda CRF 100F
ktrides2 is offline   Reply With Quote
Old Apr 24th, 2011, 7:42 pm   #2 (permalink)
Gilly's Avatar
Images: 17
If you manage to shave the heck out of it topside, you may want to just add padded bicycle shorts to your attire. Fox also makes a padded spandex like shorts. Sounds like you definitely have to lower the bike. As long as you maintain the front / rear adjustments and not just one, you should be ok, but you will lose a little ground clearance. If that's the case, to offset lowering, you can add rearsets to bring your feet higher and gain back some ground clearance.
"Oh My!" thread link... FFS!
Old Apr 24th, 2011, 7:59 pm   #3 (permalink)
What's your height?
rafaelbrandao is offline   Reply With Quote
Old Apr 25th, 2011, 6:34 am   #4 (permalink)
ktrides2's Avatar
I would rather not add yet another layer of gear, but not a bad idea. Good thought on the rearsets, forgot about that.
Originally Posted by rafaelbrandao View Post
What's your height?
5'-0"
GirlRiders.net
2003 Honda CRF 100F
Old Apr 25th, 2011, 4:35 pm   #5 (permalink)
webspoke's Avatar
Get the adjustable rear link from the S model, then lower the back some more. You can also drop the front forks 1/4-1/2 " which will help too.
You have to remove the duck bill to get at the front triple bolts, but it is not too hard. I did all of these for my 29" inseam, along with the DP low seat, and it helped a lot.
webspoke is offline   Reply With Quote
Old Apr 25th, 2011, 5:46 pm   #6 (permalink)
disgo duc's Avatar
Images: 23
you can always get a ysr 50...lol ..im a short person as well..but 8inches taller than you..the only mod i did was had a custom seat made from sargent..didnt want to lower suspension...well i did raise the forks an 1/2inch in the clamps after doing ohlins carts..
Old Apr 25th, 2011, 6:08 pm   #7 (permalink)
dimitrinassis001's Avatar
Ya another short guy here (5'-6"). Went to a local place to have a guy look at the bike and to see what he could do with the seat. He said easily can take off a half inch but said it would not be too comfortable for long rides. Better think about the adjustable linkage and shock first.
dimitrinassis001 is offline   Reply With Quote
Old Apr 25th, 2011, 7:01 pm   #8 (permalink)
Raiden's Avatar
You could trim the seat, Lower the bike and wear these.
2008 HM1100S
Raiden is offline   Reply With Quote
Old Apr 25th, 2011, 7:13 pm   #9 (permalink)
ktrides2's Avatar
Well, I shaved the seat from the bottom and I am going to replace the 2-3" of foam I removed with 5/8" gel pad and the remaining 1" of foam, I think it should be pretty good. I don't think you would even notice removing a half inch, I wonder he thought that.
If if doesn't work, on to plan B with the lowering link. I still have an untouched stock seat just in case.
Hey man, put those back in my closet, those are for special occassions.
GirlRiders.net
2003 Honda CRF 100F
Old Apr 25th, 2011, 10:03 pm   #10 (permalink)
disgo duc's Avatar
Images: 23
please dont wear those!..lol unless your wearing them in private w/ur significant other...
am i really that short??? Gochurush StreetFighter 14 Mar 18th, 2011 7:27 am
short! elixermixer Superbikes 21 Jul 24th, 2009 3:25 pm
headlight short pablo10v Supersport 0 Sep 22nd, 2008 8:04 pm
Mystery short st4duck Sport Touring 2 Oct 2nd, 2006 9:42 am
