Give us a little mrore info - Is this on your Hyuper? If so, the front signals used a very low voltage on the stock bike, and won't support aftermarkert signals.. You need to splice into the rear wiring and run the wire from there.
Also DO NOT connect the signals without the load resistor that comes attached to them, or you would destroy the LED.
If loud pipes save lives, imagine what learning to ride that thing could do!
