Jun 29th, 2012, 2:48 am
#131 (permalink)
What I have always wondered about was swingarm angle. I have talked to Brian at Podium Racing and he mentioned something in the way that the Hyper had a too flat swingarm angle (which would be solved by raising the rear). I havenīt had the time to take any measurements, but in the end it all comes down to: if it feels good, it is good. So I am unsure whether this is really important for the real world now or not.
I installed a 998 rear ride height rod. Will measure eye to eye length when I get the chance and post the numbers in here. Generally it is the same legth as the stock non adjustable rod the 08 base model comes with.
Did you already do the quarter turn throttle mod? I really liked that and it didnīt cost much (used Yamaha R6 throttle+housing).
Jun 29th, 2012, 1:46 pm
#132 (permalink)
I did do the r6 tube after I had tried the dan kyle throttle tube. I like the r6 tube much more. The swingarm angle being too flat would make sense. The combination of the much improved suspension allowing me to raise the rear has resulted in the bike being significantly more planted while cornering, maintaining the line well and not wheeling or running wide on exit. Trying these settings with the old suspension gives me nightmares because the bike was so unstable in the corner. To be honest I am not all that knowledgeable about the specifics of the geometry, what the ideal numbers are and so on. I need to work on gaining more insight into it so I can know what the changes are really doing and how the math relates to the feel. Much more in-depth than I am now. I know some, but it is never enough it seems...
Bryce
current duc... 08 hyper 1100
Jun 29th, 2012, 8:56 pm
#133 (permalink)
Now this thread is getting GOOD!! I like the first hand info of ur expirimenting and experience
Originally Posted by Thermal Runaway
Hi Ben,
Front is same as you. The rod that I have on the rear is the motowheels ( CORSE DYNAMICS Ride Height Rod: 748 / 916 / 996 / 998 / Hyper / MTS1000 / M620 / M695 / M1000 / S2R / S4R / S4RS / S4) version. The threads are the same but the length of the rod is not, if I remember correctly. I have it set at 270mm from eye to eye (center of eye), 4 threads showing on each side above the nuts.
I did this just by taking some tools with me to a track day and fiddling in between sessions. It is all feel based, and since it was the only track that was available for me to ride, tailored to it specifically. Not scientific at all! The track has a steep decent coming off of a left hand corner to a sharp right. In this short section is the braking zone where you need to cut 80mph rapidly. I am 6ft and 210lbs with gear on and having the rear up (or the front down) anymore than it is now makes me feel like I am going over the bars while on the brakes, no matter how hard I squeeze the bike. It is also pretty stable on the straight and I am able to reach top speed and steer through a slight right without feeling problems.
I try out a new track next month so I will have to make adjustments for it I am sure. Are there other measurements I could take that would be of interest?
2008 ducati hypermotard1100 w/ s4rs monster tank and seat. Custom subframe and batterybox.14 tooth front sprocket, K&N pods, cat eliminator w two brothers can and retuned ecu. Dual 4" headlights and buell xb flyscreen...
Previously:1999ktm motard, 1997ktm motard, 1996ktm duke, 1989 honda rc31(hawk650gt) w/gsxrforks,cbr900shock,vfr rearwheel and rvf/rc30 bodywork(my first bike/project)
Aug 5th, 2012, 7:01 pm
#134 (permalink)
some pictures from last race
fev photos from PBIR
Aug 5th, 2012, 9:54 pm
#135 (permalink)
^^^^^^^^ That looks so badass!!!! What type of fairing is that!?
2008 HM1100S
Aug 6th, 2012, 6:06 pm
#136 (permalink)
It is from Buell XB9R....
Aug 6th, 2012, 8:40 pm
#137 (permalink)
I thought that shape looked familiar. I just sold an XB12R. Do you always run at CCS events at PBIR? I'd like to pick your brain in person at the next race day.
Aug 9th, 2012, 11:43 am
#138 (permalink)
99.9% I am there and in december 12 we are at Homestead
Aug 16th, 2012, 5:21 pm
#139 (permalink)
If you don't mind terribly, I think I will steal that idea? Also for you, Ben or keywesthyper, are you still running the stock airbox or perhaps the EVR box? I am not sure about your class rules on inake modification. I am planning to relocate the oil crankcase breather and wondering how you had solved the problem. At this point I think I will relocate it to under the tail and just weld an aluminum box.
Bryce
Aug 16th, 2012, 9:06 pm
#140 (permalink)
Hi I dont know about Ben ,but KWHyper is running ducshop stack and KN filters and for crank breather just hose with little K&N on top.I am using TPS and special aluminium box located between cylinders.
