Grips for Hyper - Ducati.ms - The Ultimate Ducati Forum
Motorcycle.com
Old Apr 10th, 2011, 8:51 am   #1 (permalink)
Grips for Hyper
Hi folks
Have had a look through previous posts but can't quite find the answer to this one.
I just bought some progrips to change out the standard ones on my '08 1100s but seem to have seen someone saying normal grips won't fit straight off. Any truth to this before I start taking things to bits or is it just a straight swap?
Thanks!
Hamish
chunda is offline   Reply With Quote
Old Apr 10th, 2011, 9:58 am   #2 (permalink)
Rob H's Avatar
The throttle tube has little tabs on it that slide into notches in the stock throttle grip. All you have to do is file those little tabs off.
'08 Hyper 1100
'07 DR-Z400SM
Rob H is online now   Reply With Quote
Old Apr 10th, 2011, 10:42 am   #3 (permalink)
firstarsbrnwhite's Avatar
Perfect, I am installing new grips along with first oil change this week! Just picked up a set of Driven D-3 grips. Looks like a rizoma rip off to me, but I had store credit! They seem like nice quality.
2008 Hyper 1100S (Custom Pearl White Ducati Corse EVO SP Paint, SC-Project Carbon 2-1 Exhaust, Ducshop Stacks, DP Cams Flashed ECU, MetalTech Open Clutch Cover, Rizoma PP, DP Race Seat, Driven Billet Grips)
firstarsbrnwhite is offline   Reply With Quote
Old Apr 11th, 2011, 3:26 am   #4 (permalink)
Thanks for that Rob H...
Easy when you know how!
cheers
Old Apr 11th, 2011, 11:01 pm   #5 (permalink)
dreyes's Avatar
Bought the same ones & filed the tabs off. Throttle side was tight as a mofo, had to use a ton of hair spray & elbow grease to slide on. After much cursing, pushing, twisting, etc. did get it though. Good luck.
dreyes is offline   Reply With Quote
Old Apr 11th, 2011, 11:28 pm   #6 (permalink)
disgo duc's Avatar
Images: 23
acually like the driven ones better than rizoma... better design..they jus have billet collars with a molded rubber middle..rather than a full billet grip with a rubber sleeve over it..jus my 2cents since ive had both...
Old Apr 12th, 2011, 12:03 am   #7 (permalink)
bullet3z's Avatar
I am using the standard rubber Progrips and I did not file anything down to use them.
These,
Pro Grip 719 RVGS Open End Gel Grip - Street Bike - Motorcycle Superstore
bullet3z is offline   Reply With Quote
Old Apr 12th, 2011, 7:22 am   #8 (permalink)
I just got mine on last night. Super easy to get on, used hairspray. The clutch side where the large metal collar meets the grip has a small gap I could not make go away no matter how hard I tried. This bugs me a little, wondering if all of them are like this.
DRIVEN Grips Alumitech D-3 Motorcycle Grips Outrun McCoy Motorsports 0 Aug 25th, 2010 3:39 pm
Anyone change grips? Or know bar size for new grips? amanda11270 Sport Touring 24 Jun 25th, 2010 5:52 am
DRIVEN Grips Alumitech D-3 Motorcycle Grips. johnw McCoy Motorsports 2 Jan 29th, 2010 8:15 am
multistrada heated grips on a hyper? missoulamoto HyperMotard 4 Apr 19th, 2009 8:48 pm
Anyone want to sell their Hyper oem grips? ThunderDucRacer HyperMotard 4 Aug 9th, 2007 7:40 pm
