pressure sensor
Originally Posted by Outfitter540
Today while riding my check engine light came on and my speedo started reading 0. Scrolling through I get error code Press 2.2. I don't know where this sensor is located, nor do I know how to clear the codes (disconnect the battery like on a car?) I don't see how a pressure sensor could make the speedo read 0. The speedo did start reading intermittently but the speed was nowhere near accurate (120-180 mph)
Any help will be appreciated!
I had the same error code, water made it's way into the sensor. The dealer replace it under warranty and turn it around to keep from getting wet.
It is located in the nose section forward of the headlight.
AMSOIL DEALER
06 MTS 750 SPS
08 HYPER BLACK
BOTH SERVICE & MODIFIED AT EASTSIDE MOTOSPORTS, BELLEVUE, WA, USA
