Aftermarket Clutch Slave Cylinders? - Ducati.ms - The Ultimate Ducati Forum
Old Apr 6th, 2011, 6:30 pm   #1 (permalink)
DrJ
DrJ's Avatar
The other day I put some Pazzo levers on my '10 Evo Sp. Because Pazzo does not make long levers for my bike, I purchased the short ones. Now, I'm having some difficulty pulling in the clutch lever due to the lack of leverage. Therefore, would an aftermarket clutch slave cylinder resolve this issue? Are some better than others? Which ones would you recommend?
Thanks for your input.
DrJ
2010 Hypermotard Evo Sp (red, of course)
2009 Triumph Speed Triple (flat black)
2007 Segway
DrJ is offline   Reply With Quote
Old Apr 6th, 2011, 7:06 pm   #2 (permalink)
Official Sponsor
JCPakBikes's Avatar
Short levers make it pretty hard sometimes
Some tricks would be to remove two springs from the clutch pressure
This works rather well and makes the pull a lot lighter and the clutch will not slip.
I have seen many people with dry clutches do this trick without any problems. I ran this way for a while and it works!
other wise
We do offer a nice alternative for Slaves That can help somewhat with the pull
A 28mm clutch slave from Aella
Tapered style
or Bevel style
Both these have state of the art construction and new design
The pistons have a special anodized coating which allows smoother operation. another benefit is these slaves do not turn the clutch fluid black
JC
DrJ
jc@jcpakbikes.com
JCPAKBIKES
sportclassicspecialties.com
FLEDA LEGACY
ALPINA WHEELS USA
AELLA CASUNO
Old Apr 6th, 2011, 7:09 pm   #3 (permalink)
smo
smo's Avatar
Images: 3
I almost bought a clutch slave cylinder today at my dealer, but wound up buying CRG levers first.. the parts manager and one of the mechanics explained that the clutch slave cylinder will give a lighter pull to the clutch but may not make shifting any smoother or finding neutral any easier with the oem clutch parts.. i chose to rather upgrade my levers and wait till I've got some more miles on the bike to see if i still want a clutch slave..
however, in your case, a clutch slave may be your answer, especially if you still have oem clutch springs, oem pressure plate and essentially an all oem clutch, mixing and matching oem parts with aftermarket is sometimes tricky..
for a clutch slave, I considered the STM 30mm and Evoluzione 28mm... I felt the pull of a Evoluzione 28mm on a 1098 in the shop, and it was a soft enough pull for me..
2011 SF : DoubleDogMoto134dd Full System, CRG Levers and Mirrors, DP Carbon Fender and Hugger, Frame Stickers, Evotech Tail Tidy, Sans Passenger Footrests
smo is offline   Reply With Quote
Old Apr 6th, 2011, 8:26 pm   #4 (permalink)
shanetbird's Avatar
clutch slave
EVR 30MM can be found on ebay
Reduced pull in effort by about 20% with H/ D clutch springs
This is a huge differance in traffic stop & start on your left hand
checked forums here on EVR
shanetbird is offline   Reply With Quote
Old Apr 6th, 2011, 8:54 pm   #5 (permalink)
The bigger diameter you use on your slave cylinder, the softer the pull should be.
I think the biggest out there is made by NCR, 32mm
Old Apr 6th, 2011, 10:38 pm   #6 (permalink)
disgo duc's Avatar
Images: 23
oberon makes a nice slave in a 30mm and it cheap..and works alot better than my stm i had..i have short levers as well but due to a 5spring duca bike slipper i can pull with one finger..also used black coated barnett springs/soft.
Old Apr 6th, 2011, 10:53 pm   #7 (permalink)
freezer16801's Avatar
other wise
Tapered style
or Bevel style
JC
well done. You are a good person for giving solid advice first even though it doesn't do anything for your business.
I was going to offer the same advice, but you beat me to it.
08 Ducati HM
03 Yamaha R6 track bike
02 Suzuki TL1000-R RIP baby
Old Apr 6th, 2011, 11:26 pm   #8 (permalink)
08hyper's Avatar
Aftermarket slaves usually come in 28mm, 30mm, & 32mm, with the 30mm being the most popular, I run the 30mm & long levers with HD (6) springs and my pull is butter soft.
The bigger diameter you go the easier the pull will be, but the "push" will be shorter, & the clutch pack will not "separate" as far, so when you run the 30mm & 32mm you will have to pay more attention to the clutch pack height, or you could run into problems. Aloha Alex
Old Apr 7th, 2011, 12:13 am   #9 (permalink)
Official Sponsor
JCPakBikes's Avatar
Thanks Freezer
The least expensive is always the most satisfying.... so you can shed your money on other farkles
I still on occasion will remove two springs if I know I will be doing lots of stop and go. Super easy to do especially on a open clutch
amazing how well this little trick works ehe?
jc@jcpakbikes.com
JCPAKBIKES
FLEDA LEGACY
ALPINA WHEELS USA
AELLA CASUNO
Old Apr 7th, 2011, 12:16 am   #10 (permalink)
Official Sponsor
JCPakBikes's Avatar
Tru dat
If your hitting the track the larger Diameter is great since you don't need to find neutral.
but for general service the ø28 is perfect
jc@jcpakbikes.com
JCPAKBIKES
FLEDA LEGACY
ALPINA WHEELS USA
AELLA CASUNO
Ducati and After-market Clutch Master and Slave Cylinders Shazaam Hall of Wisdom 16 Dec 12th, 2011 4:30 am
Oberon Clutch Pressure Plates and Slave Cylinders moto Motowheels 0 Jul 27th, 2010 12:31 pm
Clutch Slave Cylinders wantaduc Superbikes 12 Mar 13th, 2010 2:08 am
Clutch slave cylinders ken6217 Ducati Motorcycle Chat 6 Jun 23rd, 2009 3:06 pm
