Pics of split cases needed - Ducati.ms - The Ultimate Ducati Forum
Old Apr 5th, 2011, 5:52 pm   #1 (permalink)
doon's Avatar
I need some pictures of hypermotard engine cases split for my pending court case.
The oil pic up especially
Is the centre compartment isolated from the rest of the engine?
Meaning if foreign material is on the bottom of the sump is it possible to transfer up into the gears and crank etc.
Thanks in advance
doon is offline   Reply With Quote
Old Apr 5th, 2011, 6:15 pm   #2 (permalink)
NikMusolino's Avatar
Heres one I took when we were switching out the gear prawl kit...
'09 HYM1100S Nero
Old Apr 5th, 2011, 7:44 pm   #3 (permalink)
doon's Avatar
Thanks Nik but I mean the main cases.
Old Apr 5th, 2011, 8:30 pm   #4 (permalink)
I figured... s all I had, d00n! Best of Luck to You.
'09 HYM1100S Nero
Old Apr 6th, 2011, 1:06 am   #5 (permalink)
Images: 2
Get your hands on the service manual, it has all the pics and illustrations you need.
SweFin796 is offline   Reply With Quote
Old Apr 6th, 2011, 1:45 am   #6 (permalink)
EIGHTfortyEIGHT's Avatar
Images: 110
I have a DS 1000 apart right now, same case as the Hyper. The sump is very much closed up from the crank, just big enough holes for the oil to drain back down. I cant imagine something coming up from the sump into the rest of the engine.
What happened?
EIGHTfortyEIGHT is offline   Reply With Quote
Old Apr 6th, 2011, 4:36 pm   #7 (permalink)
Abarth's Avatar
Meant to put these pics up later, when I have another mod done. But if it helps you...
---===[ 2008 Ducati Hypermotard 1100S (110,3 DIN RWHP) ]===---
|Modifications|
Termignoni 2 in 1 Full Exhaust System, Flowed Cylinder Heads, DP Race Cams, DP Race ECU (Reflashed for Wasp Kit), Wasp Power Up Kit, NGK Iridium Spark Plugs, Ducati Biggelaar Quiet Clutch modification, Lightweight flywheel (700 gram), DP Clutchplate, Carbon Clutchcover, DP Racing Seat, DP Oil Plug, Rizoma Grips, Rizoma Brake/Clutch Reservoirs, Rizoma Rear Blinkers, Painted Racing Stripes, DP Carbon Mudguard, HK Suspension Upgrade, Bitubo Steering Damper, STM Oil Breather, GiPro Gear Indicator, DP Clutch Slave, DesmoWorld Frame and Seat Plugs
Abarth is offline   Reply With Quote
Old Apr 6th, 2011, 4:45 pm   #8 (permalink)
doon's Avatar
Thanks Abarth, those open oil gallery holes are well above the sump cavity which is what I needed.
Thanks
Old Apr 6th, 2011, 5:14 pm   #9 (permalink)
Abarth's Avatar
Thanks
You're welcome!
Ahum....
|Modifications|
Old Apr 7th, 2011, 8:40 am   #10 (permalink)
Rob H's Avatar
Originally Posted by Abarth View Post
'08 Hyper 1100
'07 DR-Z400SM
Rob H is online now   Reply With Quote
Split FCRs ambi Supersport 55 Sep 15th, 2011 5:54 am
Split cases dzucati999r Superbikes 7 Dec 9th, 2010 10:21 pm
Found this in my oil--should I split the cases? CJB Supersport 3 Nov 29th, 2009 12:37 pm
Split Cases or whole new engine? Superscribe Ducati Motorcycle Chat 6 Nov 12th, 2008 10:00 pm
Pics of front number plate needed - 996 my996duc1 Superbikes 6 Jul 20th, 2006 7:30 am
