and i always thought friction zone was just a motorcycle magazine ...
Friction Zone Magazine - Motorcycle Travel and Information
if your questions is asking if you can feather the clutch while riding up the long steep gravel drive ... unless this drive has a lot of technical switchbacks, i don't think you would need to feather the clutch on a hyper ... you should be able to just ride up in gear without touching the clutch ... but that's just the way i roll.
net-net ... feathering the clutch on a dry clutch ducati will most likely lessen the clutch pack life, as it would even on a wet clutch equipped bike. you will just hear the clutch pack wear more on a dry clutch, especially if it has an open cover.
Originally Posted by needanewbike
So I read that the HM has a dry clutch and the bike I am on now has a wet clutch. I was taught that on a wet clutch you can be in the friction zone a lot more than on say a car clutch (dry) and it wont wear it out near as bad. I guess what I am asking is should I ride the HM different then my current bike as far as being in the friction zone or should i treat it more like a car and not "hang out" in the friction zone?
The reason I ask is my family has a cabin with a long steep gravel drive and going up it at a slow speed would likely be easier and safer but I do not wanna destroy my clutch.
