Flashing the stock ECU??? - Ducati.ms - The Ultimate Ducati Forum
Graves MotorsportsMotorcycle.com Classifieds!
Old Mar 26th, 2011, 6:41 pm   #1 (permalink)
Due to my addiction to adding parts to my hyper I'm looking at installing the DP cams.
Currently I've got the full system ECU that came with the termignoni and in the toolbox drawer is my stock ECU. Does anyone or can the stocker be flashed to the cam map?
Thanks in advance
Crackerr is offline   Reply With Quote
Old Mar 27th, 2011, 9:13 pm   #2 (permalink)
I am having mine done at Desmoworks/Motalab currently. Its for a 08 ecu.
craighjr is offline   Reply With Quote
Old Mar 28th, 2011, 1:33 am   #3 (permalink)
doon's Avatar
Thanks in advance
I have a dp cams ecu if you want,$320 shipped
PM me if your interested.
doon is offline   Reply With Quote
Old Mar 28th, 2011, 1:37 am   #4 (permalink)
Official Sponsor
desmoworks's Avatar
Thanks in advance
I can flash the stock ECU to the cam map. Though a lot of people seem to have had good results using the full system ECU with the cams. I've not done that myself, but read it a could of times on this forum.
Anthony Creek
Pro Italia Online || mota-lab
desmoworks is offline   Reply With Quote
Old Mar 28th, 2011, 3:35 am   #5 (permalink)
Decreasing Dave's Avatar
Images: 14
Well now that poses a good question.
The Cams ECU adds 18% fuel over the stock ECU. The 2-1 ECU only adds 7% fuel over the stock ECU. Knowing that burning more fuel makes more power, does this mean that the cams with the 7% increase in fuel will make less power and run lean than the cams with the 18% fuel increase??
Does anyone know what fuel increase is required to meet the proper air/fuel ratio with the cams installed??
I ask because I have the Cams (thanks doon) and the 2-1 ECU and would love to install the cams but A) Don't have the Cams ECU, B) Don't have the Mid-sized Performance tank to offset the fuel consumption, and C) require decent fuel mileage as I'm riding from LA to Monterey and back for MotoGP this July and don't plan on being anywhere near a highway.
Thanks,
Dave
My DOC Welcome Kit
Dave Yeski
CCS Southwest Expert #99
(apparently retired....)
2008 Hypermotard S Black!!!!
2006 Yamaha YZ450F Supermoto
Old Mar 28th, 2011, 6:19 am   #6 (permalink)
Abarth's Avatar
What do you call decent fuel milage?
I ride with the cams, 2 in 1 Termignoni and cams ECU (though reflashed/altered for the use of the WASP kit) and I get 15 kilometers on each liter of fuel. Converted that is 37,3 miles per gallon.
---===[ 2008 Ducati Hypermotard 1100S (110,3 DIN RWHP) ]===---
|Modifications|
Termignoni 2 in 1 Full Exhaust System, Flowed Cylinder Heads, DP Race Cams, DP Race ECU (Reflashed for Wasp Kit), Wasp Power Up Kit, NGK Iridium Spark Plugs, Ducati Biggelaar Quiet Clutch modification, Lightweight flywheel (700 gram), DP Clutchplate, Carbon Clutchcover, DP Racing Seat, DP Oil Plug, Rizoma Grips, Rizoma Brake/Clutch Reservoirs, Rizoma Rear Blinkers, Painted Racing Stripes, DP Carbon Mudguard, HK Suspension Upgrade, Bitubo Steering Damper, STM Oil Breather, GiPro Gear Indicator, DP Clutch Slave, DesmoWorld Frame and Seat Plugs
Abarth is offline   Reply With Quote
Old Mar 28th, 2011, 11:09 am   #7 (permalink)
I would say that the dp ecu really isnt set right to run stacks with cams. They tune their ecu kits to run the larger air box lid with their performance parts. the best bet would be to tune your bike individually because no 2 bikes really are the same.
Old Mar 28th, 2011, 5:24 pm   #8 (permalink)
Images: 14
I'm not really looking for a specific MPG number as much as I'm looking to be able to ride 100 miles confidently on one tank of fuel. That should afford me enough range to get to "the next" gas station on this trip.
I realize this and I'm planning to get a PCv but again, the air/fuel ratio is a sticking point to fuel economy.
My question still stands, but I'll try to make it clearer. Do the DP Cams REQUIRE an 18% fuel increase over stock to have the bike run correctly (all things being equal, i.e. altitude, air density, etc...)???
Even if I use the 2-1 ECU (I know this question is coming) and the PCv, and install the Cams, will the PCv be required to boost the fuel 18% to meet the needs of the DP Cams???? Same question except more directly related to my situation.
Dave
My DOC Welcome Kit
Dave Yeski
Old Mar 28th, 2011, 5:27 pm   #9 (permalink)
Wow!
Im lookin foreward to 30+ mpg.
Ive the Termi 2 into 1, the cams ecu, and want to put the stacks on.
vjdup is offline   Reply With Quote
Old Mar 28th, 2011, 5:46 pm   #10 (permalink)
Gilly's Avatar
Images: 17
Dave
Apart from added fuel, what about ignition timing. Is this different between the various ecu's?
"Oh My!" thread link... FFS!
Flashing device arnego2 Supersport 3 Jun 1st, 2010 3:56 pm
Flashing the S2R ECU's to DP specs Dodge2Dub Monster 3 Apr 24th, 2009 11:25 am
Re-flashing the ECU? High_side Sport Classic 5 Jun 14th, 2008 2:18 pm
flashing wrench xerox18 Superbikes 2 Mar 16th, 2007 9:59 pm
dip light only when flashing keithmamac Sport Touring 5 Feb 26th, 2007 1:46 pm
