Complete plug n play hid with housing - Ducati.ms - The Ultimate Ducati Forum
Old Mar 21st, 2011, 11:09 pm   #1 (permalink)
dimitrinassis001's Avatar
So I know its kinda been talked about in the past and I couldn't find a definite answer and was wondering if anyone has made a PLUG AND PLAY HID kit for our HM. I just don't want to mess around with modifying anything and playing around with wires and finding places to attach ballasts. I recently helped a friend install a slim ballast kit on his suzuki and put a kit on my girls car and honestly wasn't happy with the all the crap I had to go through. I just wanna remove the damn headlamp and put in a new one, am I asking for too much? I hope not lol.
dimitrinassis001 is offline   Reply With Quote
Old Mar 22nd, 2011, 12:42 am   #2 (permalink)
Decreasing Dave's Avatar
Images: 14
Then that's what you're gonna have to do, because HID requires a ballast to fire it up. Even offroad lights with built-in ballasts have them mounted separately in the housings wired to the bulbs.
Dave
My DOC Welcome Kit
Dave Yeski
CCS Southwest Expert #99
(apparently retired....)
2008 Hypermotard S Black!!!!
2006 Yamaha YZ450F Supermoto
Old Mar 22nd, 2011, 9:51 am   #3 (permalink)
Dave
Well I just dont want to have to modify housings and have to cut wires n stuff. I would pay the extra to have a tidy kit where some of the components are built into the housing.
Old Mar 23rd, 2011, 5:01 am   #4 (permalink)
Images: 14
The only thing you would have to modify is the cap that covers the back of the bulb. You have to drill a hole in it just offset of center. A replacement cap, should you decide to put it back to stock, is only like $10.
The rest is almost plug and play as you have to take apart one of the connectors in order to switch the connector type to the one used with the HID set-up. That takes all of 90 seconds using a really small (jewelers) screwdriver to release the pins out of the stock connector.
THEN, it's plug and play. You still have to decide where to put the ballast and the hi/lo beam switch box.
Piece of cake really.....
Dave
My DOC Welcome Kit
Dave Yeski
Old Mar 23rd, 2011, 12:34 pm   #5 (permalink)
or just buy some of those japanese hid looking xenon bulbs...not hid but not far off looks wise.....nice bright white light 10 bucks and fit in standard holder.
stevemuzicman is offline   Reply With Quote
Old Mar 23rd, 2011, 11:37 pm   #6 (permalink)
AXE
AXE's Avatar
I can also recommend a replacement bulb that I run in my truck. They are the Silverstar Ultras. They are spendy at around $40 a pair, but you will get a lot more pure white light. They are especially great when on high in the country.
I run the HIDs in my offroad rigs and they are great, but they ar definitely a PIA to connect everything. I personally thing the only way to do them correctly is to put in a fuse block with a relay right off the battery. There is a lot of amps drawn to power up those ballasts to make the light fire. You can do otherwise, but may not get the best results.
Out!
2008 Ducati Hypermotard
Old Mar 24th, 2011, 11:41 am   #7 (permalink)
Your wanting a projection lens housing?
With a ballast/relay kit mounted to the unit?
vjdup is offline   Reply With Quote
Old Mar 24th, 2011, 10:21 pm   #8 (permalink)
Yes I want a unit that has that has most of the components attached to the rear or within the housing but my main concern is having to modify the housing and wiring. I did my buddies lights on his gsxr and it needed a little modification of the housing to fit the bulb and it seems like there is condensation in the damn thing. I also did my girlfriends headlights and fog lights and needed to mess around with some relay to the battery cuz the amps (lights kept flickering) and I dont want to run into these issues. I was hoping the I could buy a unit take out my whole headlight put in a new headlight and plug it in. I think im going to try the piaa xtreme white plus just for the look of the bright white for now till I can find a true plug and play unit if its possible.
Old Mar 31st, 2011, 2:38 pm   #9 (permalink)
Well got these today. We will see how they look. I decided not to get an HID kit and not to wait for any word on a complete plug n play housing. Will take pics of before and after if anyone is interested to see. When i decide not to be lazy and they snow and ice goes away.
Old Mar 31st, 2011, 4:58 pm   #10 (permalink)
I am interested !
ICustomxXXI is offline   Reply With Quote
plug n play Alpha Superbikes 16 Mar 18th, 2011 9:03 am
Zeta Setup - Not "Plug & Play typhon HyperMotard 23 Mar 17th, 2010 9:33 am
Plug and Play Rims... Bobergfe Sport Classic 12 Dec 12th, 2009 12:08 pm
Plug & Play HID Lighting beyote Monster 1 May 17th, 2009 6:57 am
Plug and Play?? Road Scholar HyperMotard 7 Apr 16th, 2009 5:17 pm
