Mar 21st, 2011, 7:54 am
Ducati performance slipper clutch plates
Finally after too much travelling for work I'm getting close to installing my new DP slipper clutch.
I was at the Ducati dealer this weekend wanting to get new plates and they only had Barnett brand not the ducati.
The parts guy said they work better than OE.
Has anyone had experience using these or any other aftermarket brand clutch plates?
Thanks in advance
Mar 21st, 2011, 9:00 am
I don't recommended Barnet plates for the DP slipper. You should use ducati performance clutch plates.
Mar 21st, 2011, 12:58 pm
I also have a DP slipper clutch, do a lot of trackdays, and use Barnett plates, they work just fine, and are sooooo much cheaper than the OEM plates. I do think that the stock plates may last a little longer though.
Just install them as the "street" version and get your "stack" height correct, and you'll find them to work well. Aloha Alex
Mar 21st, 2011, 5:54 pm
Yah..... what he said. The Barnett's worked BETTER than the OEM.
I miss my Hyper
Now - 1977 Piper Archer
before - 08 KTM 690 SMC, 08 Hyper S (QTY 2), Daytona 955i, VFR 750, VFR 1000R, Zx-7, FZR 600 and lots of dirt bikes growing up... thanks dad!
Mar 21st, 2011, 6:45 pm
I miss my Hyper
I'll bet you do.........but there are a lot of Hypers for sale, at good PRICES too!! so kiss Mama's a** and ask her if its OK, and sign up, and we'll see you at the track!  Aloha Alex
you KNOW want tooo, 3rd Hyper's is the charm.
Mar 22nd, 2011, 12:52 am
I miss my Hyper
Haha....I knew it....it was only a matter of time.
Welcome back Todd. Good to see you here again.
Alex is right, why don't you just threaten to push her out of the plane until she agrees to fund the purchase???
Just sayin'.......
Dave
My DOC Welcome Kit
Dave Yeski
CCS Southwest Expert #99
(apparently retired....  )
2008 Hypermotard S Black!!!!
2006 Yamaha YZ450F Supermoto
Mar 23rd, 2011, 10:00 am
Got the Barnett kit but I'm concerned about the stack height.
Measured 37.5mm without the curved plate. Any suggestions on how to tailor this to 36.5 mm
Mar 23rd, 2011, 11:17 am
Depending on which pack you got, try to get as close to the 36.5mm stack height as you can WITH the spring plate. You should have a plate left over.
You can also order different thickness of metal plates from Barnett to "custom" make the pack to the 36.5mm stack height. Just make sure you follow the plate order in the "street" version in the instructions. Aloha Alex
Mar 23rd, 2011, 1:15 pm
I did Mi STM the hard way...keeping the OEM plates... I had
Double-Bench Grinded select plates. Not the friction plates or the curved plate obv.
If You know of a skilled machinist, it is perfectly safe to shave material equally off of respective steel plates. That's how I got Mi stack the way it is, but for next clutch pack, I'll go Barnett. Cheers, Alex.
'09 HYM1100S Nero
Reason: lolzsauce
Mar 23rd, 2011, 1:23 pm
Thanks again. Always a bank of knowledge!
Alex your my hero!!!
