Damaged oil plug: Replacement - Ducati.ms - The Ultimate Ducati Forum
Old Mar 20th, 2011, 6:18 pm   #1 (permalink)
DrJ
DrJ's Avatar
Well it's always something! I just did my first oil change on my 2010 Evo. I tightened the oil plug by hand and the flange part of the plug sheared off. I didn't overally tighten the plug but obviously must have. Anyway, I got the oil plug out. Now, where do I get another magnetic one and quickly? Suggestions would be appreciated. By the way, is the torque for the oil plug really 22 foot pounds?
Thanks.
DrJ
2010 Hypermotard Evo Sp (red, of course)
2009 Triumph Speed Triple (flat black)
2007 Segway
DrJ is offline   Reply With Quote
Old Mar 21st, 2011, 10:51 am   #2 (permalink)
Images: 2
Torque for oil drain plug (on a 796) is 42nm, not sure what that is in pounds.
SweFin796 is offline   Reply With Quote
Old Mar 21st, 2011, 1:12 pm   #3 (permalink)
hyperdookie's Avatar
Images: 9
That's ridiculous! You should be able to rip the threads out of the case before the shoulder breaks. Don't have any suggestions for a source other than the dealer.
Old Mar 21st, 2011, 1:17 pm   #4 (permalink)
DrJ
DrJ's Avatar
2010 Hyper Evo Sp and did it one handed and I have a bad wrist!!
J
2007 Segway
Old Mar 21st, 2011, 1:30 pm   #5 (permalink)
RUNnDUC's Avatar
Images: 13
I think I would rather have the shoulder fail before the thread is stripped in the case.
Proud owner of a 02' ST4s (BB) grey, the stealth color.
________________________________
My old ride is swinging past Pluto, other rides, some looking out, some looking in, some repairing of others and sadly the R/D on two broken and two retired. . .
”Without deviation from the norm, progress is not possible.”
– Frank Zappa
RUNnDUC is offline   Reply With Quote
Old Mar 21st, 2011, 1:54 pm   #6 (permalink)
Images: 9
While I agree with you that stripped threads aren't good, I have never seen this sort of thing happen to a drain plug.If torqued properly, the threads shouldn't rip.That being said, the drain plug should be able to withstand over-torquing to the point where it will rip the threads. I don't consider weak hardware an over-torquing "saftey feature".
Old Mar 21st, 2011, 2:02 pm   #7 (permalink)
Moderator
stryder's Avatar
That's the idea, that the plug shears/strips before the case is damaged. Much easier to deal with that way. Belt tensioner bolts have a similar design, ie shear away heads.
Regards,
Frank, '05 ST3, (Red!!)
"Veni, Vidi,....Ducati!!"
stryder is online now   Reply With Quote
Old Mar 21st, 2011, 2:31 pm   #8 (permalink)
RUNnDUC's Avatar
Images: 13
OP said that he didn’t use a torque wrench to tighten the drain plug, so we don’t know at what torque valve it was tightened at when it did fail. His question of asking for a confirmation of the torque value of the drain plug @ 22 ft. lbs.; and stating that he tightened it by hand, gives me reason to believe that he tightened it without the use of a torque wrench.
– Frank Zappa
Old Mar 21st, 2011, 2:59 pm   #9 (permalink)
Images: 9
Learn something new every day. Are these one time use kinda' things? I would think that multiple torquings on a fastener like that would weaken it. How far over the specified torque do you have to go before they snap?
Old Mar 21st, 2011, 3:46 pm   #10 (permalink)
Official Sponsor
JCPakBikes's Avatar
We have these from AELLA FOR $40 SHIPPED
HAS holes for Safety wire
and magnet
DEEP SUMP
SHORT DS motor
Thanks.
DrJ
jc@jcpakbikes.com
JCPAKBIKES
sportclassicspecialties.com
FLEDA LEGACY
ALPINA WHEELS USA
AELLA CASUNO
81 Darmah Plug Wire Replacement -How? 900SSDesmo Vintage 6 Mar 15th, 2011 4:35 am
1198S Sump Plug / Oil Filler Plug kryten2001 Superbikes 2 Apr 26th, 2010 10:58 pm
Oil Galley Plug Replacement Trout Supersport 2 Jul 3rd, 2008 7:11 am
Cush Drive replacement... when damaged only or upon milage? desmofetish Superbikes 2 Sep 12th, 2006 6:05 pm
