Ground clearance at lean angle?? - Ducati.ms - The Ultimate Ducati Forum
Old Mar 20th, 2011, 3:49 pm   #1 (permalink)
What have you guys done to improve lean angle ability on your hypers?
I have had 2 hypers.. the first was a black s 08. The new one i just got is a 2010 evo.
Im scrapping everything under the sun in the canyons with this bike. Pegs... kick stand.. Im going to try and adjust suspension to get a little more ground clearance but are there any other options besides rear sets that i may be missing?
thanks....
Jwduhon is offline   Reply With Quote
Old Mar 20th, 2011, 4:05 pm   #2 (permalink)
Fits848's Avatar
Suspension and proper fitment of rear sets will be your best bets here. Adjust your ride positioning as it feels right also.
Fits848 is offline   Reply With Quote
Old Mar 20th, 2011, 4:10 pm   #3 (permalink)
ya thats kind of what i thought... im just hesitant to put the rear set on because i like the fold up of the stock pegs... dont want to lose that... but i ride that bike so hard in the canyons that i have to do something because im grinding everything up... im going to do the suspension and see if that helps at all before i do the pegs... im about 6ft tall and 175.. do you thing the stock evo set up on the suspension is adequate ?
Old Mar 20th, 2011, 6:03 pm   #4 (permalink)
el tardo's Avatar
adjust your ride height bar to raise the rear of your bike and all problems solved.dont forget to reset your sag after
2010 black 796
dont make me badge you!!
Old Mar 20th, 2011, 7:01 pm   #5 (permalink)
johnnie27's Avatar
by an evo sp
Old Mar 20th, 2011, 10:47 pm   #6 (permalink)
Rikosintie's Avatar
I see the adjustable ride height bar off the Sp on eBay sometimes. Also the SP forks are 30mm longer for more ground clearance. I see them on eBay sometimes also.
I think that 175lb is OK for the stock springs from what I have read here. The consensus is change to 5w fork fluid with 100-120mm air gap. The stock spring is a progressive wound, a lot of people recommend replacing it with a straight wound from Racetech.
Michael
2010 1100 EVO SP
Rikosintie is offline   Reply With Quote
Old Mar 21st, 2011, 12:24 am   #7 (permalink)
freezer16801's Avatar
you should be able to get the adj. ride height bar from a lot of bikes besides the Sp. I think mine was from a 916.
Also, I take my hyper to one track day a year. Otherwise I ride my R6 at the back of the A class for about 10-15 track days/year. The first year when the hyper's suspension was stock, I had a 4 inch beard hanging from my knee sliders after a session. The next year after ride height adj., front springs and fluid change, I can't even touch a knee.
Regardless, you need to hang off this bike. Even when I rubbed sliders so much, I only touched pegs and boot sliders when I messed a corner up and my body position was wrong.
don't listen to others that say you need an SP so you don't scrape parts. Hell, Ruben Xaus didn't even scrape parts when he was backing her in with his thumb in the air, smoke rolling for reporters!
08 Ducati HM
03 Yamaha R6 track bike
02 Suzuki TL1000-R RIP baby
Old Mar 21st, 2011, 11:00 am   #8 (permalink)
thanks man... thats kind of what i thought... the sp is overkill. the mono brembos are to much brake for that bike and the olins your really not going to feel unless your on a track... so thats wht i stuck with the evo. Im going to adjust the ride bar and see what happens...
Old Mar 21st, 2011, 12:17 pm   #9 (permalink)
08hyper's Avatar
Max it out!
Like the Forum members said, get the adjustable link, set it the max length, to raise the rear, drop the forks in the clamps some to raise the front. Set your sag 35 to 45mm depending on your style.
Get some rearsets, I use the DP ones, pegs fold, and you can keep the passenger pegs if you want.
Get some good rubber and your good to go!
Just remember that the Hyper is not a true sportsbike, and has its limits, for the canyons she's fine, but if ypu want to play at the top of the "A" class you'll need a different bike.
IMHO Aloha Alex
Old Mar 21st, 2011, 2:32 pm   #10 (permalink)
thanks man.. u get out and ride the twistys in malibu?
1198 lean angle sweet999 Superbikes 16 Jan 19th, 2011 3:40 pm
Ground Clearance calebjm Sport Touring 27 Nov 10th, 2009 7:34 am
lean angle RoAdK1LL Road Racing 2 Jun 23rd, 2009 1:27 am
Lean Angle---How much is too much? brianmdavis Ducati Motorcycle Chat 18 Jul 3rd, 2008 2:01 am
Ground Clearance hyperboy HyperMotard 16 Aug 28th, 2007 11:43 pm
