Hyper´s fuel-tank leaks! - Ducati.ms - The Ultimate Ducati Forum
Old Mar 20th, 2011, 7:54 am   #1 (permalink)
Hi there,
a buddy came up with a strange thing: His Hyper´s fuel-tank is leaking. At the tank´s end where the battery and several cables are routed (I think even one ignition coil is located there), you can see a "hole" of app. 5 mm. At my bike, I´ve found the same situation, fuel is pouring out at the molded, metallic "hole":
Does anyone of you know, why the tank leaks there an why the tank has a this "hole" there?
Thanks in advance!
Cheers, Marc
HyperDesmo is offline   Reply With Quote
Old Mar 21st, 2011, 3:56 am   #2 (permalink)
Originally Posted by HyperDesmo View Post
Hi there,
Thanks in advance!
Cheers, Marc
Does that hole serve as the drainage purpose for overfilled fuel?
Honda Phantom 200cc 2006 --->2007
Honda Super Four 400cc 2007--->2008
Kawasaki Concours 1400cc 2008 --->2010
Yamaha X1R 135CC - 2010 ---> 2011
Honda PCX 125CC - 2011 ---> 2011
Kymco Myroad 700I - 2011 --- >
Ducati Hypermotard 1100 EVO - 2011--->
ohayo is offline   Reply With Quote
FS: Large Hyper Fuel Tank (NIB) Caidly Parts and Accessories 35 Feb 15th, 2011 1:47 am
Cycleworks 6.9 Gallon Fuel tank will fit your Hyper 796...video! canned_ice HyperMotard 11 Dec 28th, 2010 5:38 pm
where can I find the larger hyper fuel tank? bionicmotard HyperMotard 3 Nov 5th, 2010 1:03 pm
Water-logged hyper with extended fuel tank... bennyhab HyperMotard 17 Aug 17th, 2010 6:18 am
