If it's like the old Hypers, it goes like :
1/ Put the key in
2/ Press the command button up or down (A or B, I dont remember exactly) and hold it
3/ The turn the key
The engine should be off, and you're in the ECU setting menu.
Use A or B to navigate till you find the SET menu.
In there you can change country, CANADA, US, FRA, JAP and UK. Each country got their own default setting, and it switch km to miles.
Note : If like the old hypers, partial trip A and B are reset to 0
