Error IMMO 37.1 - Ducati.ms - The Ultimate Ducati Forum
Graves MotorsportsMotorcycle.com Classifieds!
SportbikeTrackGear
Old Mar 1st, 2011, 10:46 am   #1 (permalink)
Clarustnb's Avatar
Error IMMO 37.1
Go to start up the bike today and after hearing the fuel pump prime, no response from the starter button other than shutting off the head light.
Cycling through the dash I get to the error IMMO 37.1
Did my research online and this is an error from the immobilizer [security] function. As a separate test I entered the key card code and the bike fired up almost instantly. [the pleasures of a warm garage]
As an attempt to fix this I wiped down the immobilizer antenna [surrounding the key] and also unplugged and replugged the connectors to ensure a good fit. Still no luck starting without the key card code.
I have since taken it to the dealer to get fully diagnosed and resolved and will let you know the solution and cost when I get it.
'00 SV 650 Race prepped
'08 Hypermotard 1100s
Clarustnb is offline   Reply With Quote
Old Mar 1st, 2011, 11:53 am   #2 (permalink)
Home of vortex tuning
CDONA's Avatar
I get a CEL relating to the immobilizer about once a week, I cycle the key again, failing that, I remove and insert again for a start.
Old Mar 1st, 2011, 12:06 pm   #3 (permalink)
Clarustnb's Avatar
I had done a cycle - jump up and down - key out / key in - bump start attempt - go in and have a glass of water and try Key #2 - jump up and down - etc.
I wasn't as lucky.
Old Mar 1st, 2011, 1:46 pm   #4 (permalink)
Decreasing Dave's Avatar
Images: 14
I wasn't as lucky.
How big was the glass of water??
Dave
My DOC Welcome Kit
Dave Yeski
CCS Southwest Expert #99
(apparently retired....)
2008 Hypermotard S Black!!!!
2006 Yamaha YZ450F Supermoto
Old Mar 1st, 2011, 3:18 pm   #5 (permalink)
Clarustnb's Avatar
16 oz. half full.
Old Mar 4th, 2011, 7:33 pm   #6 (permalink)
Clarustnb's Avatar
So after 3.5 hours of dealer labor:
- The previous owner who installed the ECU did not properly ground it. Thankfully the ECU is still fine.
- Also - the connector into the back of the dash was semi-loose causing other strange errors.
Error resolved.
ST3 Immobilizer IMMO indicator James Reynolds Sport Touring 8 Oct 20th, 2009 8:24 am
Error 2.1: Pick-up Pressure error fred2602 HyperMotard 13 Feb 17th, 2008 7:55 am
IMMO 37.1 Error Cronn Superbikes 6 Jan 2nd, 2008 9:22 pm
Flashing IMMO light when key turned off Peccia Sport Touring 3 Sep 16th, 2007 3:04 pm
IMMO LED *still* flashing: normal? stryder Sport Touring 7 Sep 9th, 2007 10:54 am
