most rear shock springs are rated for a 165 to 185lbs guy ,so imo one rate higher would work better for you.
now for the 796,its spring in the rear is softer then the 1100 rear spring as i have both shocks. i weigh 185 with gear and the stock 796 spring was to soft to set the sag just right,once i replaced it with the shock from a 1100 it was perfect.796 owners dont forget to do this mod you will need to move your O2 sensor cause it will hit the reservoir of the new shock.
2010 black 796
dont make me badge you!!
