Not an oil thread... - Ducati.ms - The Ultimate Ducati Forum
Graves MotorsportsMotorcycle.comMotorcycle.com Classifieds!
SportbikeTrackGear
Old Feb 16th, 2011, 12:36 pm   #1 (permalink)
Smile Not an oil thread...
I need to change the oil (first time I do it myself on the hyper) and can't find the torque value for the drain plug.
Actually I did a search and found conflicting info (31 lb/ft or 38lb/ft?!?), so if anyone knows the correct value, please post it.
Also do you have to go to the dealer to get the crush washer or can you get an equivalent at an auto store?
Lastly how much do you tighten the oil filter. I do flush and then half a turn on my other bikes, will that work?
ilsrwy27 is offline   Reply With Quote
Old Feb 16th, 2011, 2:30 pm   #2 (permalink)
joeR6's Avatar
31 lb/ft for the oil drain plug. I wasn't aware there was a crush washer for this - I just used the washer that was already on there. Looked like a regular washer to me.
For the filter make sure that the old rubber gasket is not stuck to the engine case before you put on the new filter. I think a quarter to half turn past hand tight is fine. You can use K&N filter for the hyper which has a good ol nut on the end so you can torque to spec (9lb/ft I believe.)
09 Hyper 1100
06 Yamaha FJR1300 (sold)
04 Yamaha R6 (sold)
joeR6 is online now   Reply With Quote
Old Feb 18th, 2011, 1:04 pm   #3 (permalink)
31 lb/ft it is then, thanks. I ended up ordering an aftermarket plug to replace that stupid OEM recessed one.
Old Feb 18th, 2011, 5:10 pm   #4 (permalink)
Rikosintie's Avatar
There is a nice Stainless Steel filter available.
PCRacing USA
I see it on ebay for $99.95 all the time.
2010 1100 EVO SP
Rikosintie is offline   Reply With Quote
Not another oil thread!!!!!! Nomore76 Sport Touring 3 Mar 12th, 2010 10:17 pm
Another R/R thread simwit Supersport 6 Jul 25th, 2009 4:49 pm
Hey, where'd my thread go? MikeM Ducati Motorcycle Chat 5 Jul 13th, 2007 10:06 am
