How much time to install DP cams & do timming - Ducati.ms - The Ultimate Ducati Forum
Old Feb 10th, 2011, 11:20 am   #1 (permalink)
Like title says how much time should a dealer charge me to install DP cams, adjust the valves & do the timming of the bike?
If I install them myself what tools do I need? how much do they cost?
I'm adjusting my valves myself & have done the belt with the frequency & I'm use to do mecanic so for me it's more a time & cost issue. If it cost the same (buy the tools & do it Vs have the dealer to do it) since I don't think that I will ever have to remove back the cams it's useless to buy the tool and do it...
Thanks
joeracing1 is offline   Reply With Quote
Old Feb 12th, 2011, 8:46 am   #2 (permalink)
Thanks
if you're going to degree the cams upon install (you should since you're already there). The tools from Ducati will cost you nearly $1k. It should take a trained technician apprx 4-5hrs to perform this job.
nlzmo400r is offline   Reply With Quote
Old Feb 14th, 2011, 12:12 am   #3 (permalink)
doon's Avatar
Got a cams ecu for sale in the classifieds if you are interested!
doon is offline   Reply With Quote
Old Feb 14th, 2011, 6:43 am   #4 (permalink)
steve998s's Avatar
is it a 4V or 2V?
i have done 2v install, shim and degree in around 4 hours
4 v in around 6-7 depending (desmoquattro more often than not had bad rocker arms to change too)
and a little tuning
steve998s is offline   Reply With Quote
Old Feb 25th, 2011, 6:44 pm   #5 (permalink)
What are the tools required to do the job, I already have the degree wheel and tool for holding it on the crank, dial indicator...
Old Feb 26th, 2011, 9:55 am   #6 (permalink)
Johnb250's Avatar
I would add its nice to have two dial indicators mounted solidly to the head so no false movement, I made my mounts up and the small forks which sit on the closing shims. Also you will need two locking bolts (8mm)which go in the cam cover to lock the cam (in the notch) when you put the belts on.Also a piston stop and solid pointer and a bunch of shims.
Johnb250 is offline   Reply With Quote
Old Feb 26th, 2011, 10:43 am   #7 (permalink)
I would say its always better to do it ur yourself. Always within reason of the price of the tools. Good thing is that you can always resell the tools and make some of the money back or you can always install someone elses and charge.
Me personally, I love having tools
krisnet55 is offline   Reply With Quote
Old Feb 28th, 2011, 11:16 am   #8 (permalink)
Someone having the installation instructions? I have the maintnance manual but it's for OEM cams not DP so for the timming I guess it<s not the same values?
Old Feb 28th, 2011, 1:58 pm   #9 (permalink)
Johnb250's Avatar
There are no instructions. And after talking to two dealers I am convinced they dont have a clue either, I get the impression they just install them and the customer goes "you degreed the cam didnt you ?" they reply "Ya". Probably because it takes a long time to fiddle with the adjustments, no dealer would make much money if they did it correctly 3-5 hrs I would guess.
I would also add that I set mine at 108 ( OEM is 115 ) which seemed to be the setting from previous threads, but I would also say the slightest change in belt tension makes a difference .Probably its best to just make them both exactly the same. Good luck.
DP termi 2-1 install PDF and DP tank bag install PDFs ... johnchypermotard HyperMotard 2 Apr 27th, 2010 7:00 pm
Wanted Ducati ST2 CAMS OR 900 CAMS SURVEYOR Parts and Accessories 0 Feb 11th, 2010 1:56 am
749R Cams vs. 999R Cams ??? SittingDuc Superbikes 4 Aug 14th, 2009 11:55 pm
Inj.cams v carb. cams ambi Supersport 4 Apr 21st, 2008 6:44 pm
How much for cams install? daversj HyperMotard 3 Oct 12th, 2007 2:30 am
