Feb 10th, 2011, 3:22 am
796 guys -a quick question
i installed my 14t front sprocket day one from getting the bike home.my question is when in sixth gear at 4k rpm's im at 64mph on the speedo
you guys with the stock 15t front can you tell me what mph your at when in sixth at 4k rpm's please. im to lazy to put my stock on back on then to have to take it right back off.
and thanks ahead guys!!
2010 black 796
dont make me badge you!!
Feb 10th, 2011, 12:50 pm
changing the sprocket does not affect the speedometer reading on these bikes because the speedometer is read from the back wheel....
Feb 10th, 2011, 2:10 pm
Huh?
Changing the sprocket would change the RPMs at any certain speed no matter where the speedo reads from.
Right?
Feb 10th, 2011, 3:13 pm
changing the front sprocket will change the mph reading because the engine is spinning faster with a 14t front sprocket over a 15t sprocket. my guess is about 10 to 15 mph.
just wanted someone with there stock 796 to check for me!!!!
2010 black 796
Feb 10th, 2011, 5:16 pm
Correct
Right?
Correct
Speedo not affected by sprocket changes. GPS will confirm. This only happens when speedo gets info from Engine sensor on coutershaft, like my FZ1. As Hankin says the Duc sensor is on the rear wheel
Mike
? CUSHMAN GOLDEN EAGLE
Feb 10th, 2011, 6:53 pm
Yup, speed sensor is on the back wheel. Easy to spot, just look for the black wire and mag pickup on the swingarm side.
'10 hyper 796
'06 KTM 450exc(Plated)
'03 TTR-125
Feb 10th, 2011, 7:18 pm
i sure hope to god you guys are kidding!!!!!!!!!
has no one here ever rode a 10 speed bike,its called gear ratios!!!!!!!!!!
yes the speed of the bike in mph will be different then the rpms' when you change a sprocket compared to a stock gear ratio in the same gear !!!!!!!!!!!!!!!!!!!
one tooth in the front is same a three in the back,so by changing the front down one it makes the engine turn faster then the stock one and the rpm's will be higher to equal the mph
please re-read my question ,lol
2010 black 796
Feb 10th, 2011, 7:22 pm
please re-read the question!!!
2010 black 796
Feb 10th, 2011, 7:25 pm
read danielson!!!
2010 black 796
Feb 10th, 2011, 8:47 pm
so basicly can one of you 796 guys ride your bike in sixth gear at 4k rpm's and tell me what speed your going???
2010 black 796
