EVR Slipper Clutch Installation Question
My EVR slipper clutch arrived but with no instructions. However, the removal of the OEM clutch components was rather straightforward as was the EVR installation except for one step. With the steel friction plates, do you line up the accentuated notch for each steel plate with the others, or do you rotate them and, if so, with what spacing? From the EVR YouTube clip, which is in Italian, this step was unclear.
Thanks.
DrJ
2010 Hypermotard Evo Sp (red, of course)
2009 Triumph Speed Triple (flat black)
2007 Segway
