You can open up the stock airbox and even install a performance filter like (K&N, BMC, DNA) as long as your keep the exhaust stock, & the stock ECU will work fine. You can also install a CAT eliminator which will give you better throttle responce and a better exhaust note.
These two mods are the most you can do to a stock bike with stock ECU, and will give you the "BIGGEST BANG FOR THE BUCK" you will gain from 4 to 6HP. Aloha Alex
PS: this goes for the 08-09 bikes, not sure about 10s & up, but I'm not sure why it would not work the same.
