Originally Posted by WakeDude
Dirkwright would say G-flex. It is some type of new bonding agent that with plastics seems super strong.
-Alex
Thanks for the quick response, but I am not sure a permanent epoxy bond would be the best solution. Covering up the connections would be unsightly and possibly not fix the issue.
Will the larger tank allow access to the top side of the throttle bodies without complete removal/drain?
