How to raise the bike for working? - Ducati.ms - The Ultimate Ducati Forum
Old Jan 20th, 2011, 12:49 pm   #1 (permalink)
I'm looking to do some work on the bike and need to get a lift/ jack, all the blurb says it should be lifted via the frame but there ain't one at the bottom, is it ok to lift the bike using the bottom of the engine. So I roll the jack/lift under the bike and up up and away or..................
2008 Hypermotard 1100
2010 Triumph Tiger SE
"If you want the Rainbow, you gotta put up with the rain"
twozzie is offline   Reply With Quote
Old Jan 20th, 2011, 1:29 pm   #2 (permalink)
sick50ford's Avatar
I like to ratchet strap to the rafters, Forks and subframe with a floorjack assist if needed. Depends on the job at hand.
Taking the tires in to get swapped I use a rear stand and straps up front. I have used the jack by itself but don't like to.
Old Jan 20th, 2011, 2:36 pm   #3 (permalink)
All depends on what you are doing to the bike. Front and rear stands work fine unless you're removing the rear swingarm or shock. If you need to get the forks off a under-stem stand works for that.
So what exactly are you doing to the bike?
'11 Hypermotard 1100 Evo
'03 DRZ400E, converted to SM
Darren is offline   Reply With Quote
Old Jan 20th, 2011, 3:16 pm   #4 (permalink)
Corse1's Avatar
Images: 2
Man thats a small work space
I have to do steering head beerings this winter so will be slinging around the frame and up over the trusses of the garage.............
Corse1
03 ST4s ABS (2006 -)
07 Tuono 1000R (2011 -)
03 Aprilia Tuono RSV 1000 Racing (2011-2011 Crashed)
06 1050 Speed triple (2009-2011)
Corse1 is offline   Reply With Quote
Old Jan 20th, 2011, 3:30 pm   #5 (permalink)
The first wee job will be to check and set the sag which requires the rear end to be fully extended. The rafter and strap is not an option for my garage as it's fully finished with no rafters exposed.
Old Jan 20th, 2011, 3:41 pm   #6 (permalink)
NikMusolino's Avatar
+1 on Darren's comment... T-Rex Racing makes a Front Stand with Triple Tree adapter specifically for the Hyper. I called and asked since I couldn't distinguish for certain what was what on their website. I am about to take off mi forks & send to Race Tech, so I am utilizing a rear stand as well as said front stand. If You notice there is a sizely hole in line with the steering stem on the bottom triple clamp of the Hyper that the front stand's triple tree adapter penetrates and holds from there. They are good stands, although many may tell You to drop the coin on Pit Bull. They have worked for me and I purchased front & rear for a price I could more easily justify than if I went the Pit Bull route. Plus, they come in Black.
'09 HYM1100S Nero
Old Jan 20th, 2011, 3:53 pm   #7 (permalink)
thing is I'm looking to see if I can utilize it on the Triumph also
Old Jan 20th, 2011, 5:01 pm   #8 (permalink)
Demotivational Member
bebopdontstop's Avatar
Images: 2
These go on sale often. I got one for $279.00 with a coupon. Keep a look out.
1000 Lb. Capacity Motorcycle Lift - Lifts & Stands - Automotive & Motorcycle
I like the wide open spaces; where two guns beat four aces.
bebopdontstop is offline   Reply With Quote
Old Jan 20th, 2011, 6:58 pm   #9 (permalink)
Decreasing Dave's Avatar
Images: 14
You don't need a stand for this.
Just pull the rear up and take your measurement. it may even stay in the topped out position all by itself. You don't have to have the wheel off of the ground, just topped out on the suspension.
Even if it doesn't stay up by itself, it's best to have another person to help you if you are setting sag correctly anyway.
Dave
My DOC Welcome Kit
Dave Yeski
CCS Southwest Expert #99
(apparently retired....)
2008 Hypermotard S Black!!!!
2006 Yamaha YZ450F Supermoto
Old Jan 20th, 2011, 8:20 pm   #10 (permalink)
Dave
Brilliant !! this gets me through the first bit.
I'll probably get a jack/stand regardless just in case.
Recommend a stand for working on the bike. DesmoDisciple Supersport 24 Apr 19th, 2012 8:55 am
'04 749 Amazing bike... When it's working! Please HELP!!! xXxGaTesxXx Superbikes 3 Jun 15th, 2010 9:15 pm
The interesting things you find when working on your bike SP3 Ducati Motorcycle Chat 2 Mar 22nd, 2010 9:40 pm
How to raise the back of the bike? Help me! saab Sport Classic 13 Apr 23rd, 2009 11:42 am
