2010 Gear Shifter - Ducati.ms - The Ultimate Ducati Forum
Old Jan 10th, 2011, 1:46 pm   #1 (permalink)
akdoc's Avatar
2010 Gear Shifter
I'm curious to know how I can get more clearance between the left foot peg and the shifter. I have a new pair of Sidi's and it's really hard to get my toes under the shifter to shift. Any sugesstions?
Dr. John
2010 Ducati Superbike 1198 White
2010 Ducati HyperMotard 796 White (sold)
2009 Kawasaki ZX6r (sold)
2005 Honda 600rr black (sold)
2005 Honda 600rr red (sold)
2004 Aprilia RSVR 1000 gray (sold)
2003 Honda 600rr yellow (sold)
akdoc is offline   Reply With Quote
Old Jan 10th, 2011, 2:14 pm   #2 (permalink)
Home of vortex tuning
CDONA's Avatar
I could get my A* tech 6 boots with this adj.
Old Jan 10th, 2011, 2:37 pm   #3 (permalink)
Decreasing Dave's Avatar
Images: 14
Taking the rubber insert out of the footpeg helps as well as adjusting the lever upwards a bit.
Dave
My DOC Welcome Kit
Dave Yeski
CCS Southwest Expert #99
(apparently retired....)
2008 Hypermotard S Black!!!!
2006 Yamaha YZ450F Supermoto
Old Jan 11th, 2011, 1:46 am   #4 (permalink)
08hyper's Avatar
! It would be better if you left the lever on the motor "straight up" or at 90 degrees, to have the best leverage over the trans for up/down shifting.
If you want to make the shift lever higher adjust the rod to make it longer, and if thats still not high enough, make a longer shift linkage rod , (like me), that way you'll have the leverage over the trans the way it should be. Aloha Alex
MTS1200: Gear shifter on backorder, wtf? gts_rider Multistrada 31 Sep 19th, 2011 12:34 am
1098 gear shifter Alpha Superbikes 1 Oct 23rd, 2010 6:16 pm
Firstgear Fall 2010 Gear Guide RevZilla RevZilla.com 0 Sep 24th, 2010 9:08 am
New Motorcycle Gear July 2010 from RevZilla.com RevZilla RevZilla.com 0 Jul 7th, 2010 9:36 am
PCIII USB, Dynojet quick-shifter, GIPRO Gear Displey TAftonomos Parts and Accessories 7 Apr 15th, 2010 8:43 pm
