Hard or soft run in? - Ducati.ms - The Ultimate Ducati Forum
Motorcycle.com Classifieds!
Old Dec 25th, 2010, 9:28 pm   #1 (permalink)
Question Hard or soft run in?
Gents i will be getting me bike in another few days time.
May i have some light on this?
dirtflame is offline   Reply With Quote
Old Dec 25th, 2010, 9:32 pm   #2 (permalink)
08hyper's Avatar
Run her like you stole her! Aloha Alex
Old Dec 25th, 2010, 9:38 pm   #3 (permalink)
Cool Lol
Lol agent recommended to run like in rpm
Not more then 6 before first oil and filter change.
Old Dec 25th, 2010, 9:44 pm   #4 (permalink)
i've always ridden em in pretty hard, but i always make sure the bike has properly warmed up first and always break them in in the mountains, use alll the gears going up and down the rev range...........and try not to hold full throttle on the rev limiter
Mr R is offline   Reply With Quote
Old Dec 26th, 2010, 1:54 am   #5 (permalink)
el tardo's Avatar
heat cycles are the best for run in. if you dont understand dont ask,lol
2010 black 796
dont make me badge you!!
Old Dec 26th, 2010, 4:57 am   #6 (permalink)
Steve C's Avatar
There are going to be a bunch of opinions on this so I'll just toss mine in here for what it's worth. Todays engines are built to much closer tolerances than they use to be so breaking in a motor is not as critical as it was "back in the day". Air cooled motors definitely should be heat cycled as part of the break in process since they change dimensions more than our water cooled cousins. When I got my Yamaha FJ 1200 motor (1349cc) back from Hank Scott he recommended the heat cycling method and also to vary the RPM, no long duration steady speeds. The rings seated perfectly and 6 years later the motor still runs great with minimal oil usage. He also recommended no full throttle or redline blasts until everything was seated in well IIRC, 600 miles was the ballpark number. Enjoy the new ride when it arrives
Steve C
www.hamptonbengals.com
2008 Hyper 1100
2008 GSXR 750 Track Bike
1972 TM 250J-"Roger DeCoster"
Steve C is offline   Reply With Quote
Old Dec 26th, 2010, 5:34 am   #7 (permalink)
Question Thanks !
So any guide on what speed to follow?
Shifting gears normally or frequently?
Old Dec 26th, 2010, 6:16 am   #8 (permalink)
freezer16801's Avatar
I don't think full throttle is bad in the low and midrange once warmed up, the redlining can't be good though.
As for speed, various speeds is the best for the motor as others have stated.
I took it relatively easy for the first 600. Then after that it was on. I don't think you will have to worry about heat cycles. I hit 250 degrees F easy in traffic when new. Now I have to sit in stop and go for an hour in 90 degree heat before I get to 240 or do a warm track day.
I ran through the stock rear BT014 in 1400 miles. So, obviously I didn't take it too easy on the thing.
08 Ducati HM
03 Yamaha R6 track bike
02 Suzuki TL1000-R RIP baby
Old Dec 26th, 2010, 7:07 am   #9 (permalink)
Chilehead
st2lemans's Avatar
Images: 74
Yes, lots of hard acceleration and engine braking. Easy to do around here. Avoid constant RPM, even on the highway (if you must use the highway), and change gears often to use them all.
Yes, that as well.
Tom
1985 LeMans
1986 LeMans w/ sidecar
1992 XV250
1998 ST2
2003 SS1000DS
2003 999R #29
www.motogiro.com
st2lemans is offline   Reply With Quote
Old Dec 26th, 2010, 8:10 am   #10 (permalink)
Question Heat cycles
Sorry for my ignorance! What is heat cycles?
How hard is too hard to start a 1098? Noc748 Superbikes 36 Oct 19th, 2011 6:33 am
Front Fork too soft, help me fix Indy36 Multistrada 9 Oct 3rd, 2009 4:10 pm
'02 748 soft front brake mrodey Superbikes 5 Jun 17th, 2009 11:42 am
Soft paint cgociferS4R Monster 12 Oct 19th, 2008 5:48 pm
848... Soft? Karna Superbikes 16 Apr 2nd, 2008 5:30 pm
