Shifting issues - Ducati.ms - The Ultimate Ducati Forum
Old Dec 22nd, 2010, 3:50 pm   #1 (permalink)
Shifting issues
Ok so I have had my Hyper for 8 months 3 oil changes later I still can't shift into neutral once the bike has warmed up. This is driving me absolutely nuts!!!!! I have had it in the shop to be fixed they say it is in working order and that there is nothing wrong.
Anyone got any ideas?
HyperSlider is offline   Reply With Quote
Old Dec 22nd, 2010, 6:19 pm   #2 (permalink)
I had the same problem, it turned out that the clutch was not disengaging fully due to the adjustment on the clutch lever. I had it on the shortest travel. I dont know but its worth a try to put it on full travel and see.
Ducati Hypermotard '08
Ducati Monster 620S '03
HalaHyper is offline   Reply With Quote
Old Dec 22nd, 2010, 8:35 pm   #3 (permalink)
freezer16801's Avatar
I was also going to suggest a good clutch fluid bleed. Start at the master cylinder and then move to the slave cylinder.
08 Ducati HM
03 Yamaha R6 track bike
02 Suzuki TL1000-R RIP baby
Old Dec 23rd, 2010, 11:47 am   #4 (permalink)
johnchypermotard's Avatar
fwiw, i always start the bleed @ the slave cylinder, then finish up @ the master cylinder.
Old Dec 23rd, 2010, 10:08 pm   #5 (permalink)
el tardo's Avatar
another very good trick to get air out of the line is to zip-tie the lever to the handle bar over night so the air can move up the line and out the master.you can lightly tap the line with a screw driver to loosen any air bubles left in there
works every time!!!
2010 black 796
dont make me badge you!!
Old Dec 24th, 2010, 6:11 am   #6 (permalink)
works every time!!!
I always forget to add that one. I do it every time and it does help.
08 Ducati HM
Shifting Issues Lonestar Aviator Supersport 16 Apr 2nd, 2010 3:47 pm
Shifting issues - Multi-620 thewheel69 Multistrada 4 Aug 11th, 2009 2:26 pm
Ruff Shifting... False Neutrals... and some other issues giogolf Sport Classic 26 Jul 14th, 2009 3:05 pm
Gear shifting issues koucki Sport Classic 10 Jul 9th, 2009 10:36 am
