More on hyper cam kit - Ducati.ms - The Ultimate Ducati Forum
Old Dec 19th, 2010, 11:02 am   #1 (permalink)
Question More on hyper cam kit
Hi again all,
Can anyone tell me if the following cams will fit a 2009 1100s hyper. Cams part no 14812451B and 14812441B. Full cam kit with ecu no 96519208B.
Thanks for the help in advance Luca
luca is offline   Reply With Quote
Old Dec 19th, 2010, 12:41 pm   #2 (permalink)
08hyper's Avatar
Originally Posted by luca View Post
Hi again all,
DP performance only sells one set of cams for the DS1100 engine, call your dealer for the DP cam kit, and inside the kit will be seperate # for the cams themselves. Aloha Alex
Old Dec 19th, 2010, 12:59 pm   #3 (permalink)
Question
Thanks Alex,
Reason why l ask is that l am told these cams came out of a 07 hyper. l wanted to know if they would fit the 09 moter? Is there any differance in the newer engine / cams for it.
Old Dec 19th, 2010, 2:32 pm   #4 (permalink)
Home of vortex tuning
CDONA's Avatar
'07 to '09 are dual spark motors, the '10 uses different cases, flywheel, and single spark, not sure on compatibility from '09 to '10
Old Dec 19th, 2010, 4:04 pm   #5 (permalink)
08hyper's Avatar
Thanks Alex,
Yes, they should fit , 07-09 is a DS1100, 010 & up is a new engine.
always check the part# with Ducati parts dept to be sure, I would hate to see you buy a set of stock cams.... Aloha Alex
New hyper or older hyper? labbedds HyperMotard 22 Nov 10th, 2010 12:23 am
Hyper Hello's from PDX 1badduck Welcome and Introduction 2 Sep 8th, 2010 2:44 pm
Hyper 796 or refinish the garage? -> the Hyper won! spindrift Welcome and Introduction 5 Jul 14th, 2010 1:17 am
buy used 08 hyper or wait for new 796 hyper? nikkihyperr HyperMotard 12 Oct 10th, 2009 12:00 pm
New Hyper S shabek HyperMotard 13 Jan 28th, 2008 1:15 am
