1098 Compatibility parts ? - Ducati.ms - The Ultimate Ducati Forum
Old Dec 15th, 2010, 9:54 am   #1 (permalink)
Few questions regarding what parts I could eventually add to the bike...
I'm looking at 7 spoke wheels from the 1198.
I know the rear axle is not the same diameter (55mm vs 46mm), but would the eccentric hub from a 1098-1198 fit our swimgarm ?
Fork...
I cant justify the super expensive cartridges. It just kills me to see Ducshop is charging nearly 1500$ while the new 30mm for superbike are around 1k...
So, anyway to swap the whole fork + clamp for a Ohlins SBK setup ?
Thanks.
Old Dec 15th, 2010, 12:57 pm   #2 (permalink)
I'd also be interested if someone has done a fork swap.. I think I remember hearing about GSXR forks on either a sport classic or a monster...
nitsuj8686 is offline   Reply With Quote
Old Dec 15th, 2010, 4:11 pm   #3 (permalink)
Chouch,
unless you want to lower the whole bike, using a 1198 fork set up will not work all the great due to them having about 45mm less travel. I do agree with you that the cartridge kit is expensive as hell..... but there are more options over the ohlins.... some are a little cheaper. They are all going to be expensive now though because they are in demand. While working at a ducati dealer, i saw this trend all the time..... in a year or so when something newer and "cooler" comes out, the aftermarket prices for everything hypermotard will drop.
HankinSD is offline   Reply With Quote
Parting out 848 - 1098 parts - 998 parts ToxinsOut Parts and Accessories 15 May 30th, 2010 9:37 pm
2003 620 Sport parts compatibility snlsmith Supersport 4 Jul 21st, 2009 7:03 am
1098 parts? Ducposer StreetFighter 0 Jun 17th, 2009 6:21 pm
848 Parts Compatibility with 748 & 1098 Darkwingduck Superbikes 1 Apr 9th, 2009 9:17 am
Parts Compatibility (Ducati and others) rummaggio Supersport 10 Dec 31st, 2007 8:29 pm
