Is this a solution to my fueling woes.. - Ducati.ms - The Ultimate Ducati Forum
Old Dec 13th, 2010, 3:56 pm   #1 (permalink)
Hey has anyone tried the MemJet module for the 2010 Evos?
They specifically say its for the Siemens ECU and claims to dial up more aggressive mapping by cheating the air intake temp to increase performance with the by-product of 'completely resolving the low end jerky throttle' 'engine will run smoother and cooler due to better mapping'.
Since the Fatducs are not going to be available and the PowerCommander V is still under dev wondering if this might be worth a try for $200...
Would love to hear if anyones running one of these and if it made a diff.
Welcome to MemJet Modules!
Roadsurfer is offline   Reply With Quote
Old Dec 13th, 2010, 4:13 pm   #2 (permalink)
johnnie27's Avatar
i'd speak to anthony at desmo works, put a pipe on it and get a free ecu flash..if i was in the u.S that would be money for jam
Old Dec 13th, 2010, 4:27 pm   #3 (permalink)
Which is only an option if you live near LA. Unfortunately I dont ... though I'd like to hear from anyone who's had their ecu reflashed by for the stock bike .. Also Im looking to get a Sc Project slip on not the Zards.. When he starts accepting mail in ECUs for reflashing that might be worth it. Though the MemJet is still a cheaper option at the moment ... if it actually works...
Old Dec 13th, 2010, 4:54 pm   #4 (permalink)
johnnie27's Avatar
i believe you can send AC by mail, your ecu..or for just over $500 bucks by a pro-tune
Old Dec 13th, 2010, 7:01 pm   #5 (permalink)
NikMusolino's Avatar
I say forgettabout the memjet, get a G2 Ergonomics Delrin Throttle Tube and Duc Shop stacks. This will dramatically alter the Hyper's response characteristics. Intake before exhaust...
'09 HYM1100S Nero
Old Dec 13th, 2010, 9:41 pm   #6 (permalink)
freezer16801's Avatar
I wouldn't add stacks to a stock bike without increased fueling capabilities. The bike is lean from the factory and it would lean out even more with stacks.
I've heard of devices that trick the ecu into thinking that it needs to stay in the warmup circuit. I've seen a ton of them on ebay for other bikes and never trusted them. The ebay ones weren't plug and play. I think there are other options for a couple extra $$ that might give you better results.
If you were to go this route, I'd suggest getting a vdst and a gastester at the minimum to see what your afr's are. Dyno tuning would be even better. By them time you do all of this stuff, you could've invested in a power commander or other piggyback controller with a dedicated map made for a bike similar to yours.
08 Ducati HM
03 Yamaha R6 track bike
02 Suzuki TL1000-R RIP baby
Old Dec 14th, 2010, 4:59 pm   #7 (permalink)
Mr Mike's Avatar
type memjet into the search box and you will see at least 10 previous Posts agout it
? CUSHMAN GOLDEN EAGLE
Old Dec 14th, 2010, 8:32 pm   #8 (permalink)
it's the first I've heard about it and I've been here for almost 3 years.
08 Ducati HM
Old Dec 15th, 2010, 12:34 am   #9 (permalink)
el tardo's Avatar
i have the memjet on my 796 with full exhaust and open air box and no popping. yes it works and works well. its adjustable for different mods you do to your bike.now it only tricks your ecu for fuel no timing so yes a race ecu is better but for the cost you cant beat it. the 796 hyper has the siemens ecu too.
the memjet is big for lots of bikes.if you look on the aprilia forums all the dorso's and shiver use it.
what i have found out to be ture is the ducati market doesnt mind spending top dollar for parts and thats why you dont here about stuff like this. i have owned lots of brands but never seen the type of money spent to up grade a bike like ducati owners.
2010 black 796
dont make me badge you!!
Old Dec 15th, 2010, 8:37 am   #10 (permalink)
Activator's Avatar
I was just wondering... I have an '08 1100, and the FatDuc has really helped smooth things out, but I'm still plagued with jerky low-speed throttle. I also have a G2 throttle tube installed, but no matter how "smoothly" I give the bike throttle, there are way too many times when I feel like I'm on a bucking bronco!
Do you think the MemJet would do a better job smoothing things out? As I read it, the FatDuc simply richens the air/fuel mix, whereas the MemJet actually modifies the ECU.
I'd be willing to spend $200 for smoother response.
2008 Hypermotard 1100 - Red (sold)
2006 Mutistrada 620 - Gloss Black (sold)
2004 BMW R1100S - Grey (sold)
2000 Aprilia Pegaso - Blue (sold)
Activator is offline   Reply With Quote
Siemens fueling check-in jryden HyperMotard 8 Nov 16th, 2010 6:24 pm
Fueling woes... bmartinek HyperMotard 7 Aug 26th, 2010 1:31 pm
Low-Fueling Newbee's Summary Sputniks StreetFighter 8 Aug 10th, 2010 10:37 am
Update on my fueling issue mmoore StreetFighter 18 Dec 20th, 2009 2:52 pm
My new 696...bad fueling? desmodrone Monster 16 Jun 25th, 2008 8:27 pm
