Dec 4th, 2010, 2:14 pm
DP CAM ECU Problem
I just finish intall my Ducshop stack and DP cam ECU
Put the gas tank temporarily just to check how it works before doing something else. And BZZZZZ it doesn start.
So i plug the vdst on it to check and find a chort to ground message. Disconect the battery try back the original unit and same things.
I have check everywhere on the bike and doesn't find anything wrong.
Each time i have reset the tps for each unit, the only other things that have done is disconect the fat duc ( don't need anymore) and reconect the original wire
I also have check the starter relay fuse ( ok) and the starter fuse ( ok too)
Anybody have an idea ?
Motorcycle Maniac
10 Ducati Streetfighter
08 Ducati Hypermotard
08 Aprilia SXV-550
10 Gas Gas TXT280 Pro
06 Kawasaki KXF-450
96 Beta Thecno
95 Beta Thecno
Dec 4th, 2010, 4:34 pm
Problem solved
I just came back from walk with my dogs ( try to change my mind ) and i tought that maybe the neutral light wasn't glow in the dash .
Check it back, touch the shifter a bit and Bingo . It was mecanicaly in neutral, but not electricaly. Start it up fire instantly and run goods.
NOw it's Cold beer time
Motorcycle Maniac
08 Aprilia SXV-550
06 Kawasaki KXF-450
96 Beta Thecno
95 Beta Thecno
Dec 4th, 2010, 5:46 pm
I'm glad it worked out for You. Wide open is better... What did You do with Your O2 sensor? Off-topic, I just low-speed lowsided mine on the slippery downhill off-camber into mi neighbourhood road... thankfully, the Speedymoto sliders & Motivation bar ends did their job. The left rearset is spent and the left tank fairing has a quarter size chinkaderus. Woodcraft rearsets were on their way anyway...&Now that I just ordered a set of Twilltech Carbon tank fairings and fresh teflon... Tis a Happy Holideay, indeed! Even if I totalled this bike--knock****, I'd still buy another one.
'09 HYM1100S Nero
Dec 4th, 2010, 9:04 pm
Hi Nik !
For now my O2 sensor is still there,but unused (Run open loop now) then i will put a bazzaz Z-Afm with a Bazzaz Z-FI with a 0 mapping ( all blank only to collect A/F ratio data.I whant to be sure that the A/F Ratio is ok with my set up.Then when the set-up will be perfect i'll plug it with a Vances & Hines plug.
Sorry for your low side adeventure, but like you said when a bad luck like that happen its a chance to modify with better parts.
And like you if i would total mine, i would buy another one too. Its the most pleasing and reliable bike i have ever had. When i bought my SF i was thinking that it was going to replace my HM, but now that i've ride both back to back, i know that it won't be the case. They are both very fun and very different bike, with a little edge on the fun factor for the HM.
Cheers !
Motorcycle Maniac
08 Aprilia SXV-550
06 Kawasaki KXF-450
96 Beta Thecno
95 Beta Thecno
Dec 5th, 2010, 10:39 pm
have you considered the power commander V and auto tuner? I think they come in much less expensive than the bazazz unit.
When bike doesn't start, I always check the simple things and most of the time it is the damn kill switch, kickstand switch, clutch switch, or some other stupidity.
After putting together a former suzuki of mine I racked my brain until I figured out I mounted the tip over switch upside down. The poor switch probably thought I was in australia!
08 Ducati HM
03 Yamaha R6 track bike
02 Suzuki TL1000-R RIP baby
Dec 6th, 2010, 12:45 am
Makes you wonder if they have to flip their switches over when they get their new bikes.......
....you know, just to be "normal".
Dave
My DOC Welcome Kit
Dave Yeski
CCS Southwest Expert #99
(apparently retired....  )
2008 Hypermotard S Black!!!!
2006 Yamaha YZ450F Supermoto
