Rear Subframe replacement znd install? - Ducati.ms - The Ultimate Ducati Forum
SportbikeTrackGear
SportbikeTrackGear
Old Nov 21st, 2010, 8:38 pm   #1 (permalink)
laslunas's Avatar
Wanted to see who here has replaced their rear subframe with an aluminum model? Are you happy? How hard was the install? Was it just removing the seat and exhaust?
laslunas is offline   Reply With Quote
Old Nov 21st, 2010, 8:54 pm   #2 (permalink)
NYSport's Avatar
Images: 4
Not too difficult. I removed the tank but you don't need to, just raise the back of the tank up. Looks good and saves some weight.
Rear Subframe replacement znd install?-p1010113.jpg   Rear Subframe replacement znd install?-p1010120.jpg   Rear Subframe replacement znd install?-p1010122.jpg
Old Nov 21st, 2010, 9:22 pm   #3 (permalink)
lelenb's Avatar
Images: 12
I replaced the subframe and it is a little more complex than just removing the seat. When I installed the subframe I decided to be lazy and just to loosen the fuel tank and remove the original subframe under it. I used my bicycle stand to hold up the rear portion of the tank and that worked well. I found the hard part was attaching the rear tank rubber supports. I even enlisted the small hands to fit in the tight confines and he couldn't do it.
It took me as long to put on the two rubber supports as it did to remove the original subframe, tail lights, turn signals, exhaust, and the battery and the rubber tank supports. The easiest way if I were to do it again would be to remove the fuel tank.
I like the quality of the subframe from Motowheels, though it is a bit too shiny. It does cut down on a few pounds up top.
Lelen
Hyper S
Old Nov 21st, 2010, 9:33 pm   #4 (permalink)
lelenb's Avatar
Images: 12
That is one clean Hyper. Did you paint the heads? My heads are flaking.
Lelen
Hyper S
Old Nov 21st, 2010, 9:43 pm   #5 (permalink)
hyperdookie's Avatar
Images: 9
Shame on you!
Old Nov 21st, 2010, 10:22 pm   #6 (permalink)
lelenb's Avatar
Images: 12
Originally Posted by hyperdookie View Post
Shame on you!
I always keep a pen of shirtless boys on hand, is there something wrong with that?
Lelen
Hyper S
Old Nov 21st, 2010, 11:07 pm   #7 (permalink)
Images: 9
Eh, who am I to judge. I, myself am working on a pen of shirtless girls but they keep escaping.
Old Nov 21st, 2010, 11:12 pm   #8 (permalink)
Decreasing Dave's Avatar
Images: 14
Duct Tape......
Or, my personal favorite......
Saran Wrap and a ball gag.....
Dave
My DOC Welcome Kit
Dave Yeski
CCS Southwest Expert #99
(apparently retired....)
2008 Hypermotard S Black!!!!
2006 Yamaha YZ450F Supermoto
Old Nov 22nd, 2010, 2:37 am   #9 (permalink)
its very simple and straight forward. I replaced my exhaust at the same time so i just pulled the subframe with the slip ons attacked. Worked very well. I only lifted the subframe and did not remove it completely.
HankinSD is offline   Reply With Quote
Old Nov 22nd, 2010, 7:15 pm   #10 (permalink)
NYSport's Avatar
Images: 4
There not painted and I haven't noticed any flaking. I wash the bike about once a month and that's about it. Thanks.
Hypermotard Aluminum Subframe Install Pics. barneybarn HyperMotard 137 Oct 27th, 2010 11:26 am
monoposto rear subframe - 999R JohnMH Parts and Accessories 0 May 6th, 2010 6:36 am
Desmo Subframe Replacement? Dames Superbikes 1 Apr 16th, 2009 6:12 pm
Help!: 2001 996 OEM battery replacement install problem Roy Superbikes 6 Oct 26th, 2008 10:06 am
998S Mono Rear Subframe???? jules_1972 Superbikes 3 Jan 29th, 2006 5:01 am
