I need a really good condition stock clutch - from any dry clutch Ducati. I need it complete with basket, plates, etc...
I'll offer a $250 credit towards an EVR slipper clutch (in stock) if you ship me your stock clutch as described above. If you want to do this pm me.
Some info on the EVR clutch.
EVR Ducati CTS (control torque system) slipper clutch eliminates rear wheel chatter on corner entry improving stability and ultimately lap times on the track as well as safety on the street. Includes 48 tooth clutch plates and basket. mota-lab's EVR Slipper Clutch kits includes the following items that nobody else includes making this the most complete slipper clutch on the market (every single piece needed is included - no reusing original parts!).
+ M20 and M25 mounting kits which cover all dry clutch Ducati models.
+ Pre-installed pressure plate throwout bearing to help make instillation easier.
+ EVR Stainless steel clutch retainer springs.
+ EVR stainless steel clutch retainer bolts.
+ OEM steel bolts to mount the clutch basket.
+ OEM oil seal for the included hub spacer.
EVR slipper clutches use a patented technology that greatly improves operation and clutch life when compared to the competition. This dry clutch typically lasts four times as long as the competition and there is no periodic maintenance required!
