Titanium Bolts/axles all around! NCR/Poggipolini
As some of you know desmoworks is now an official NCR dealer. We'll be launching a new site, etc... soon and our first major batch of products are on the way right now (including a titanium 1098R frame and TON of other stuff).
NCR/Poggipolini titanium fasteners are considered among the top in the world and used throughout MotoGP, F1, SBK, etc...
The key features are thread rolling and forged heads.
According to Poggipolini -
"Thread rolling offers many advantages to the overall quality of our products. Unlike other threading processes, the alloy is neither removed nor wasted, but displaced.
The grain structure of the thread is reformed in continuous unbroken lines which follow the thread contours. This process strengthens the threads in 3 ways: tension, shear, and fatigue resistance."
And regarding forged heads -
"Forging offers many advantages to the over all quality of many of our products.
Unlike the simple machining of fastener heads or fittings, the forging process molds the grain structure of the material into the shape of the finished product which strengthens tension, shear and fatigue resistance."
Here is a list of what we can supply for the 848, 1098 and 1198 - I'll post some images soon when we get these in. We've got some cool bits coming such as the complete rear axle in titanium!
ENGINE 863060102853 4 Bolts for cam cover $56.06
ENGINE 101100612 12 Bolts for pulleys $146.20
ENGINE 102100515 4 Bolts for Thermostat $56.23
ENGINE 101100615 4 Bolts for engine cap $48.73
ENGINE 101100515 1 Bolt for spray nozzle $10.83
ENGINE 101100615 8 intake manifold bolt kit $97.47
ENGINE 101100625 9 Alternator case bolt $127.16
ENGINE 101100630 2 Alternator case bolt $30.26
ENGINE 101100620 2 Alternator case bolt $26.31
ENGINE 101100890 4 Engine carter bolt $102.96
ENGINE 101100875 3 Engine carter bolt $71.51
ENGINE 101100635 8 Engine carter bolt $116.69
ENGINE 101100675 2 Engine carter bolt $47.39
ENGINE 101100625 6 Clutch bolt $84.77
ENGINE 101100680 3 Clutch bolt $73.83
ENGINE 101100690 1 Clutch bolt $25.74
ENGINE 101100625 1 Oil pump bolt $14.13
ENGINE 101100840 2 Oil pump bolt $36.49
ENGINE 863060102935 16 Rocker arm bolts kit $549.12
ENGINE 863060102936 1 Bolt for pick up check $34.32
ENGINE 863060102937 1 Engine water drain plug bolt $34.32
ENGINE TOTAL KIT $1,790.52
FRONT FRAME 310180808 2 Titanium M8 washers $14.53
FRONT FRAME 208100804 2 Titanium auto-lock M8x1,25 nuts $45.99
FRONT FRAME 101100850 2 Titanium bolts m8x50 $40.44
REAR FRAME 863060102963 4 Complete bolts kit $102.96
REAR SPR. FLANGE 212101005 5 Titanium auto lock 12p.,M10x1,5 nuts $268.63
FRONT BRAKE DISK106100820 10 Bolt tit.tctx M8x20 $174.17
TRIPLES CLAMPS 101100825 9 Bolts: M8x25 $140.03
FORK BOTTOMS 101100830 4 Complete fork bottoms bolts kit $65.89
STEERING DAMPER101100615 1 Bolts: M6x15 $12.18
STEERING DAMPER101100620 2 Bolts: M6x20 $26.31
REARSETS 106100820 4 Bolts: M8x20 $69.67
CHASSIS TOTAL KIT $960.80
TITANIUM AXLES NCR. 1 Front Axle $972.40
TITANIUM AXLES NCR. 1 Engine axle $972.40
TITANIUM AXLES NCR. 1 Rear Axle $1,573.00
TITANIUM AXLES TOTAL KIT $3,517.80
