For 1098/1198:
http://www.store.commoto.com/adler-a...8-p-29614.html
For all other Ducati dry clutch models:
http://www.store.commoto.com/adler-a...h-p-29615.html
Some more info for you:
50% less clutch pull -
Other slipper clutches have higher than standard clutch spring load. There is no need for a slave cylinder with this setup!
NO clutch lever vibration -
You won't be able to tell that the APTC mechanism is working... no funky vibrations through the lever like you get with most other slipper clutches.
No special tools required (that aren't included) -
This clutch is easily installable with standard mechanics tools.
Adjustability -
Included are 3 sets of shims to adjust the amount of engine braking that you desire. Very detailed setup instructions are included too so you aren't left in the dark. We are available for setup help as well or we'll install it for you here at the shop.
How it works -
This clutch uses a double hub design with helix profile using 4 opening springs and 4 closing springs. Most slippers use 6 ball bearings on ramps and the single inner hub which moves on the ball bearings. This requires periodic disassemble and lubrication. Not a bad design or function, but we believe this clutch design to be superior due to the design, ease of adjustability, lack of maintenance required and very high quality craftsmanship.
