DUCATI DIAVEL & MTS1200 O2 CONNECTOR
This sensor plugs in between the OEM air temperature sensor and will "trick" your current ECU making your system open loop. The result is the bike will run richer over the full rpm range and increase HP and runs much smoother. Shift-Tech tested it on a Diavel with Termignoni full exhaust and had a gain of 4HP and 5lbs torque as shown on the dyno sheet.
Installation takes 5-10 minutes and no special tools needed. With an aftermarket tuning device like PC5 or others this will also enable you to tune the bike through the full rpm range. This O2 connector fits the Ducati Diavel and Multistrada 1200 with OEM or DP ECU and you only need one per bike. Direct plug in, no modifications needed. Please note that your current on board outside air temperature gauge in your dash will not read the current exact air temperature ( approx. 25 degrees less) with this devise plugged in - a small price to pay for a bike that runs great!
