1098 Closer Shims Now Available - Ducati.ms - The Ultimate Ducati Forum
Go Back   Ducati.ms - The Ultimate Ducati Forum > Site Sponsors > Supporting Vendor Archives > EMS
Old Jun 15th, 2007, 12:52 am   #1 (permalink)
Site Sponsor
ducatimike's Avatar
Ducati changed the designed of the closer shim on the 1098 slightly from the previous design used on the 851, 888, 916, 996, 998, 748, 749, 999, ST4, ST3, S4 Monster, and the 2V DS 1000 motor. The ID of the shim is the same but the position of the chamfer on the OD has been moved toward the bottom of the shim. The reason for this is to obtain clearance with the adjacent cam lobe. The attached pic shows some old closer shims compared with the new 1098 closers.
I now have the 1098 closer shims in stock individually. I am currently gathering information as to the range of sizes typically needed for the 1098 to evenutally offer complete shim kits. The sizes currently in stock are from 2.50 mm through 4.15 mm.
The opener shims for the 1098 have not changed in design from the older 4V ones.
Mike
99 ST4
05 Honda 450F
01 YZ 250
92 CR 500
www.emsduc.com
www.ducati-owners-group.com
ducatimike is offline
Is the 1098 a "plug" product? parkec Superbikes 46 May 25th, 2008 11:37 am
My first impressions (1098) Cron Superbikes 38 Apr 23rd, 2007 8:56 pm
1098 development questions answered amullo Superbikes 11 Mar 9th, 2007 7:34 pm
NEW!!! 1098 Specs Info and New Pics!!!!!!! Harry Superbikes 54 Nov 10th, 2006 11:15 am
