Motowheels M900 project - Ducati.ms - The Ultimate Ducati Forum
Old Jan 27th, 2009, 11:07 am   #1 (permalink)
Ducati.MS sponsor
moto's Avatar
Images: 30
This is a monster that I built before I was involved with Motowheels in 1998. It is another bike that does not get ridden much anymore and may be gone pretty soon.
This is a picture of it around 2002.
We painted it for the first Monster challenge and came in second:
This bike is extremely light. It is all carbon, magnesium and titanium.
The wheels are BST carbon wheels. Rotors are BREMBO "Narrow Band 4 Pad" Front Rotor with SPIEGLER "Free Floating" Brake Rotor Buttons. Calipers are the BREMBO "4 Pad Radial" Cast Caliper with CARBONE LORRAINE Brake Pads: 4 Pad which are much more progressive than the OEM brembo pads.
The CF Front Fender: 748-998,Mon'00+,SS,ST is vented by inserting a screen. The forks are 748R forks with Ohlins internals and a MW Billet "Showa 100mm" Radial Lowers:748-998/SS/Mon/MS.
Barely visible are the titanium bolts:
TI Fork Axle Pinch Bolts
TI Rear Rotor Bolts: Mon/SS/888/ST
TI Front Caliper Mounting Bolts: Radial
The brake line is a FREN TUBO "Kevlar" Brake Lines: F&R 749R/999R 2004
Hidden behind the RHINOMOTO Front Axle Slider is a TI Front Axle
Old Jan 27th, 2009, 11:09 am   #2 (permalink)
Ducati.MS sponsor
moto's Avatar
Images: 30
The Lower triple clamp was a one off made by Alex Ortner. The top triple and bar risers was made by Cycle Cat. It was one of the first production prototypes.
Also pictured is the BREMBO "GP" Forged Radial Brake M/C: 19x18, a carbon instrument housing, superbright Black KELLERMANN Micro1000 "Halogen" Turn Signal and FEBUR Oversize Oil Cooler: Monster with a custom made screen.
The steering damper mount is a MW Billet Steering Damper Mount: Monster with a OHLINS Universal Steering Damper 68mm
The headlight is a JWS HID Headlight mounted in a blackpoweder painted Harley Headlight bucket. Larry from the "Busy Little Bike Shop" made the billet mount. We used titanium hardware to keep the weight down.
Mirrors are the little CRG Blindsight Mirror.
Reservoirs are RIZOMA .
Old Jan 27th, 2009, 11:10 am   #3 (permalink)
Ducati.MS sponsor
moto's Avatar
Images: 30
Ths RCV instrument kit features an adjustable shift light.
Also pictured are the RIZOMA Med Billet Reservoir- Horizontal: Black , Cycle Cat bar risers, CF Ignition Cover: Early Monster
The CF Fuel Tank has been coated on the inside to protect it from ethanol.
CF Fuel Cap w/ Silver QR filler: Ducati/MV/Yam
Old Jan 27th, 2009, 11:10 am   #4 (permalink)
Ducati.MS sponsor
moto's Avatar
Images: 30
The motor is what sets this bike apart.
The motor has a 944cc hi comp pistons. It has a flowed twin plug head, titanium rods, KEIHIN FCR Carb Kit.
It also features: EVOLUZIONE Performance Plugs & Wires, MOTOWHEELS Billet Magnetic Drain Plug , MOTOWHEELS Billet Oil Fill Plug, Sil-Moto Equal Length "Spaghetti" Header , FRENTUBO "Kevlar" Oil Cooler Lines , FRENTUBO "Kevlar" Cylinder Head Oil Lines, abd Magnesium engine cover, and CF Cambelt Cover.
We are using a SURFLEX Slipper Clutch w/ Plates. We painted the pressure plate a deep red. It is protected by a RCM Billet Clutch Cover "Open Air".
Also pictured is OHLINS Rear Shock: M600/750/900 '94-01 with a billet mount, CycleCat rear sets, CF Side Panel, CF "Corse"Heel Guards: 748-998 , CF Belly Pan: Monster "Long" and SPEEDYMOTO Frame Slider
Old Jan 27th, 2009, 11:11 am   #5 (permalink)
Ducati.MS sponsor
moto's Avatar
Images: 30
The Ohlins rear spring was replaced with a titanium spring:
Sil-Moto Equal Length "Spaghetti" Header was ceramic coated in a silver aluminum finish
Billet Suspension hoop is made by Rizoma
Red lens was replaced with a clear CLEAR ALTERNATIVES Lens. A superbright HEAVYCYCLES "LED" Tail Light/Turnsignals: Monster/Buell integrated board replaced the CA supplied LED light n the kit.
Chopped the tail and used a MW License Plate Relocator: 749/999 to mount the plate.
A high quality pre preg CF Passenger Seat Cover: Monster was painted with a red stripe and clear coated. You could actually sit on this tail with out hurting it.
The Black KELLERMANN Micro1000 "Halogen" Turn Signal were mounted on MW Turn Signal Relocator Bracket
The exhaust is a Sil-Moto Hi Mount Slip-ons: M600-750-900, 00+
Old Jan 27th, 2009, 11:11 am   #6 (permalink)
Ducati.MS sponsor
moto's Avatar
Images: 30
We have a BST Carbon Fiber Rear Wheel on the rear with an iron BRAKETECH "Full Floating" Rear Rotor. We used a Fren Tubo Kevlar line in the back.
To lighten the bike up some more: we used DP "CF" Chain Adjuster Plates: Monster on the ends of the swingarm and titanium bolts through out: TI Rear Rotor Bolts: Ducati Button, TI Brake Caliper Thru Bolts,
A RHINOMOTO Rear Axle Slider: Monster/ST/SS protects the back. We had to run a drill bit through the center of the swingarm to remove the burr in the middle which prevents the slider rod to slide through.
To lighten up the drive train, we used:
AFAM Light Front Sprocket: 14T-520, TI front sprocket bolts, D.I.D. 520ERV3 Chain, AFAM Rear Sprocket: BST/Marchesini, TI Sprocket Nuts and Titanium Cush Drive Pin,
MW Aluminum Sprocket Cover
MW Billet Reverse Shift Lever: Ducati
Billet Clutch Slave Cylinder 29mm
DP aluminum flywheel
Fren Tubo Kevlar Clutch line
Old Jan 27th, 2009, 11:12 am   #7 (permalink)
Ducati.MS sponsor
moto's Avatar
Images: 30
Old Mar 12th, 2009, 8:25 am   #8 (permalink)
Tiz
Tiz's Avatar
really nice bike
I have the same belly pan for my M900 but some troubles to put it on the left side.
can you post more picture on how/where it is fixed.
thx
Previously: 600 Mostro Dark and Gold
Now: 900 Monster S Black
My Topic
Tiz is offline   Reply With Quote
Old Mar 13th, 2009, 12:04 pm   #9 (permalink)
Ducati.MS sponsor
moto's Avatar
Images: 30
Bike is not available for pictures right now,
Here are some old pictures:
-M
Old Mar 13th, 2009, 2:45 pm   #10 (permalink)
Images: 6
Ducati Island
Are you guys going to enter any bikes in the Laguna Ducati Island show?
2000 996S is offline   Reply With Quote
Motowheels 999R Project moto Motowheels 12 Sep 15th, 2011 11:49 am
Motowheels 1098 project bike moto Motowheels 77 Jul 21st, 2011 9:25 pm
WTB: M900 93-99 any condition. Project surfguygrif Monster 0 Oct 29th, 2008 12:01 pm
Motowheels M696 project moto Motowheels 12 Sep 30th, 2008 12:06 am
Motowheels Sport Classic Project moto Motowheels 1 Apr 3rd, 2008 12:19 am
