Sport Classic project - Ducati.ms - The Ultimate Ducati Forum
Old May 9th, 2008, 1:57 pm   #1 (permalink)
Ducati.MS sponsor
moto's Avatar
Images: 30
We started on a Sport Classic Project a few weeks ago after spending some saddle time on the bike to find out what we want to do.
I don't like the riding position too much. It is more agressive than any of my Superbikes... The original wheels look great--but they are just too heavy for a modern bike. It could use a better headlight for night riding. The rear end needs to be cleaned up and simplified...
We are still experimenting with different parts. We are going to use what we have in stock at first and show some different options as this bike develops.
The first thing has got to be wheels. We have had reports of the SC1000 losing almost 30 lbs of rotating unsprung weight when going to the BST wheels. Since we don't have any BST rears in stock at the moment--we are going to try the MARCHESINI Forged Aluminum Wheels: S4,ST,Mon for now. It is over $1000 less than the BST wheels but quite a bit heavier.
The front wheels required a speedo spacer on the left side. We swapped the rotors to an SPIEGLER "ABM Full Floating" Front Rotor: 748-998/Monster/ST/MS/SS and the calipers to the BREMBO "4 Pad" Cast Caliper: 65mm Axial. Now this should make a huge difference in braking.
The rear wheels was basically a direct bolt on. We used also added a SUPERSPROX "Stealth" 520 Sprocket: BST/Marchesini, D.I.D. 520ERV3 Chain , AFAM Light Front Sprocket: Testastretta 14T-520
I think they look good on the bike--but I want to try the new 7 spoke BST wheels that look closer to the old magnesium wheels of the late 70;s--plus the bike will be tranformed with the lighter carbon wheels. The forged aluminum wheels only bring it up to par with the S2R1000...
We added our new lightweight MW 7000 Slipper Clutch w/ plates. This will eliminate some of the rear wheel hop when grabing a bunch of gears on those down hill turns.
and some bling:
SPEEDYMOTO "Leggero" Sprocket Cover
MW Aluminum Sprocket Cover
MOTOWHEELS Billet Q/R Fuel Cap: 749/999,MS,SC
We are trying out tail light/plate kit: MAD DOCTOR License Plate/Tail Light/Turn Signal Kit: Monster. It is almost a direct bolt on--we just had to slot the holes slightly.
The light is bright enough that I might consider tinting the lens so the kit blends into the shadows...
We are experimenting with adjustable bar risers--It looks like we will just end up making a 2.5 inch adjustable riser kit instead.
Fitted a CF Belly Pan: Monster "Long" for fun:
We are playing around with top triple clamp coversion kit for SBK forks, a HID headlight, different exhaust system, bar end turn signals, bar end mirrors...I'll keep you posted.
Old May 11th, 2008, 7:33 am   #2 (permalink)
[QUOTE=... a HID headlight...[/QUOTE]
This is something that I've been waiting for
ct_mazi is online now   Reply With Quote
Old May 31st, 2008, 9:05 am   #3 (permalink)
akillya's Avatar
Images: 9
+1 for the HID kit!!!
"All the tools, none of the talent"
rod@tplracing.com
http://tplracing.blogspot.com/
akillya is offline   Reply With Quote
Old Jul 11th, 2008, 3:10 pm   #4 (permalink)
Official Sponsor
New pipes
More pix to come
GT
2004 S4R
Previously owned 1972 GT750 and Mid 60's 250 Single
Ronin1 is offline   Reply With Quote
Old Jul 15th, 2008, 1:00 am   #5 (permalink)
Official Sponsor
Custom Headlight
Info to follow... soon
GT
2004 S4R
Old Jul 17th, 2008, 10:15 am   #6 (permalink)
atomemphis's Avatar
I've shared with Brian quite a bit that I'm quite interested in that headlight setup (custom bracket to replace U-bracket & JW Speaker light, HD bucket) on my Monster.
I think its a great update to the older headlight and it has to be gobs brighter. Looks great!
1999 M900 hooligan cafe bike, 1998 M900/888 "trackster", 2001 M900 grocery getter, 2003 2v748 based on 748/996RS tech.
atomemphis is offline   Reply With Quote
Old Jul 17th, 2008, 11:55 pm   #7 (permalink)
Ducati.MS sponsor
moto's Avatar
Images: 30
Side Views:
Old Jul 18th, 2008, 2:10 pm   #8 (permalink)
Ducati.MS sponsor
moto's Avatar
Images: 30
It looks like we are going to make a run of the headlight brackets to fit both Monsters and Sport Classic.
Old Aug 4th, 2008, 8:45 pm   #9 (permalink)
Ducati.MS sponsor
moto's Avatar
Images: 30
Old Aug 7th, 2008, 4:20 am   #10 (permalink)
BlackSport's Avatar
Thumbs up
Nice job! Bike looks great. Ride report? Where did you get the black reservoiers?
BlackSport is offline   Reply With Quote
Cure for the Sport Classic Riding Position geospencer Sport Classic 114 May 1st, 2012 9:58 pm
howdy, and questions on the sport classic 1000 biposto corks67 Sport Classic 31 Aug 20th, 2009 11:02 pm
Monster S2R1000 to a Sport 1000 Biposto motorbike65 Sport Classic 14 Sep 19th, 2008 7:30 pm
Motowheels Sport Classic Project moto Motowheels 1 Apr 3rd, 2008 12:19 am
Sport Classic Cup? EarthBM Sport Classic 25 Nov 20th, 2007 5:33 pm
