Motowheels 4 Spring Slipper Clutch w/Plates
High quality Complete Italian made Lightweight 4 Spring Slipper Clutch helps prevent rear wheel lock up on deceleration. Lighter weight, reduces rotating mass and improves throttle response. The 4 spring design has a much lighter clutch pull than the 6 spring design and is lighter than the 6 spring design.
The Aluminum billet -slipper clutch includes:
anodized billet aluminum clutch drum
aluminum top pressure plate
aluminum basket
aluminum Surflex friction plates
bolts with alloy spring retainers
The Motowheels slipper uses original clutch springs- or you can add the slightly stiffer "polished stainless steel clutch springs" for less slipping.
All billet aluminum basket, drum and pressure plate save up to 4 pounds of rotating weight when used with the aluminum discs and .25 pounds lighter than the Motowheels 6 spring slipper. The aluminum basket and plates are significantly quieter than the OEM set up.Top quality Surflex carbon/aluminum friction discs are included for ease of installation, extra weight savings, quiet function and longer basket life.
The Motowheels slipper clutch is considered by many to be the best value on the market, with more components and features than much more expensive brands. Comparable to other systems which cost over $1800 complete.
This is a "must have" for track or fast canyon riders. This will allow you to drop into the most optimum gear with out worrying about wheel hop, loss of traction or upsetting the chassis.
Fits all dry clutch Ducati (748-998,749-999,MH900e,ST, Multistrada and all dry clutch Monsters S4, S4R and 900 Supersports) For the 1098, add the 1098 slipper clutch nut below to your order.
http://www.motowheels.com/italian/my...rcycle%20Parts
