ECU Reflash - Ducati.ms - The Ultimate Ducati Forum
Motorcycle.com
Old Aug 29th, 2011, 5:33 pm   #1 (permalink)
Ducati.MS sponsor
moto's Avatar
Images: 30
ECU Reflash
Option 1:
MW Tuning/Rexxer ECU Remap
MW Tuning remaps are simple and easy to do. Simply remove your factory ECU and send it to us to remap. We will remap your ECU and send it back out the same day.
Only have slip-ons? No problem remap your bike now and if you change to a different exhaust later you can send us back the same ECU for a $25 map change!
We have maps available for most fuel injected Ducati's, including the Desmosedici, Monster and Superbikes. Map types for improved OEM systems, slip-ons, and full systems.
Retail is $250 for a remap. Purchase a full system from us and we will remap your ECU for $150. Purchase a slip-on system and get a remap for $200.
Contact Tech@motowheels.com for map availability. We also have blank ECU's available for purchase if you would rather keep your stock ECU.
Option 2:
MWtuning/Protune Reprogrammer
If you prefer the flexibility of having a tool which will allow you to do it yourself, consider the Protune.
Protune also allows you check, read, and clear the check engine light from your Ducati. Since the original map is stored on the Protune, the maps can be switch back to stock at any time.
If you want to upgrade the map later because you have further modified or changed your Ducati you can do this by sending us the just Protune unit for a new map. The ECU stays on the bike.
If you decide to return your bike back to stock condition, you can load the stock map on the bike which loads the Protune map back onto the Protune unit. You can either send it back to us to get a new map for your next bike--or sell the entire unit to someone else, recovering some of your initial costs for the tool.
Reflash jrodgers Multistrada 16 May 12th, 2011 9:30 am
ECU reflash required? Chi-town748 Superbikes 3 Apr 29th, 2011 12:04 am
Reflash jrodgers Multistrada 2 Apr 25th, 2011 4:40 am
considering a reflash vspinner StreetFighter 9 Aug 4th, 2010 9:53 pm
Reflash your 999 ECU lost1 Superbikes 5 Feb 20th, 2008 3:30 pm
