SIDI Boots - Ducati.ms - The Ultimate Ducati Forum
Motorcycle.com
Old Aug 26th, 2011, 7:28 pm   #1 (permalink)
Ducati.MS sponsor
moto's Avatar
Images: 30
SIDI Boots
Sidi Fusion
$200.00
  • Vertebra system Achilles and rear calf protection panel.
  • Replaceable nylon toe scuff pad.
  • Replaceable outer ankle protective cap.
  • Nylon shin deflector plate.
  • Fully encapsulated heel cup.
  • DuPont polymer toe shift pad.
  • Dual Compound Sole
  • Composite inner sole.
  • An elastic panel adjacent to the entry zipper allows a bind free zip and
    improved fit.
  • Removable arch support.
  • Double stitched in all high stress areas.
  • Zipper and Velcro closure system.
  • Lorica outer construction.
  • Perforated Teflon treated nylon lining.
Sidi Cobra Air
$250.00
Cobra Boots have a Dual compound sole and composite inner sole. Protection includes: Vertebra system Achilles and rear calf protection panel. Thermoplastic resin ankle protection. Bolt on (no Velcro!) replaceable, adjustable and aerodynamic nylon scuff pads on the toe. Nylon shin deflector plate. Replaceable shock absorbing heel cup. Padded Achilles area. Fit and Function includes Removable arch support. Lorica outer construction. Double stitched in all high stress areas. All bolt on parts are replaceable. An elastic panel adjacent to the entry zipper allows a bind free zip and improved fit. DuPont polymer toe shift pad. Perforated Teflon treated nylon lining.
Sidi ST
$395
Composite inner sole. Dual compound sole. External ankle brace system. Sidiā¬"s exclusive cam-lock buckle system for easy entry and boot removal while still offering a perfect glove like fit. Bolt on (no Velcro!) replaceable, adjustable and aerodynamic nylon scuff pads on the toe. Padded Achilles area. DuPont polymer toe shift pad. Lorica outer construction. Removable arch support. Double stitched in all high stress areas. Closable air vents on the foot outer. All bolt on parts are replaceable. An elastic panel adjacent to the entry zipper allow a bind free zip and improved fit. Perforated Teflon treated nylon lining. Replaceable, Shock absorbing heel cup. The ST can accommodate riders with up to an 15-inch calf diameter 12.5 inches above from the bottom of their heel.
Sidi Fusion Rain
$275
    improved fit.
FREE domestic shipping on all SIDI Boots. Contact us for details.
Difference in sidi boots? jeremyh007 Apparel and Accessory Chat 15 May 3rd, 2012 5:36 pm
Sidi Boots 10.5 (45) seight311 Gear 3 Apr 7th, 2011 9:16 pm
SIDI Boots moto Motowheels 4 Nov 15th, 2010 8:03 pm
Sidi Vortice Boots sinex HyperMotard 4 Mar 31st, 2009 10:54 pm
Sidi Doha Boots Kramer Ducati Motorcycle Chat 9 Sep 30th, 2006 8:51 am
