CORSE DYNAMICS Magnetic Drain Plug: Testastretta - Ducati.ms - The Ultimate Ducati Forum
Graves MotorsportsSportbikeTrackGearMotorcycle.com Classifieds!
Graves Motorsports
Old Jul 13th, 2011, 11:27 pm   #1 (permalink)
Ducati.MS sponsor
moto's Avatar
Images: 30
CORSE DYNAMICS Magnetic Oil Drain Plug: Testastretta
Corse Dynamics oil drain plugs are a great way to upgrade your Ducati with a part that is both beautiful and functional!
  • Our "double hex" design allows you to remove or install these plugs with either the factory allen wrench OR an ordinary wrench or socket.
  • Our plugs incorporate a Viton O-ring to ensure proper sealing against the engine. This provides a good seal every time
  • Our plug comes pre-drilled for safety wire on all six faces. Our plugs include a rare earth magnet to collect any metal bits that might be inside your engine, our magnet is rated at six times the strength of other competing companies.
Fits the following models:
Desmosedici, Monster 1100, Monster S4RS, 848/1098/1198, 749/999 ( deep sump models), 996R/998R, Streetfighter, Diavel, MTS12...
Old Jul 14th, 2011, 1:51 am   #2 (permalink)
Ducati.MS sponsor
moto's Avatar
Images: 30
For non Testastretta motors ( non deep sump motors):
  • Our "double hex" design allows you to remove or install these plugs with either the factory tool OR an ordinary wrench or socket.
  • Fits all non deep sump Ducati Motors
Old Feb 6th, 2012, 4:16 pm   #3 (permalink)
whats the difference between these and the stock (for sfs). From what I've read the stock drain plug is magnetic as well. Is it onlt the finish/predrilled?
ducdrummer is offline   Reply With Quote
Old Feb 6th, 2012, 4:51 pm   #4 (permalink)
Ducati.MS sponsor
moto's Avatar
Images: 30
The CORSE DYNAMICS Drain Plug is a double hex design that allows you to use the original allen tool, a socket or wrench so it does not strip as easy.
The original is an allen head design that has a slight taper in it which makes it difficult to get a tool in it.
It comes drilled for safety wire.
The rare earth magnet is over 6 times stronger than the OEM magnet.
It is made of 7000 series aluminum. The OEM is steel.
-M
Old Feb 7th, 2012, 8:22 am   #5 (permalink)
quality, will be picking one up before the spring!
CORSE DYNAMICS Frame Plug Kits moto Motowheels 0 Jun 2nd, 2011 11:35 am
CORSE DYNAMICS Magnetic Oil Drain Plug moto Motowheels 0 Apr 29th, 2011 11:41 am
Magnetic drain plug - anyone try one of these yet? NickD Ducati Motorcycle Chat 15 Jan 8th, 2008 2:25 pm
