BREMBO "RCS" Forged Radial Brake Master Cylinder - Ducati.ms - The Ultimate Ducati Forum
Graves Motorsports
Old Apr 29th, 2011, 3:59 pm   #1 (permalink)
Ducati.MS sponsor
moto's Avatar
Images: 30
$365.00 *
*Includes a free bottle of MOTUL RBF600 Racing Brake Fluid 0.5 litre ($20 value)
* Brake lever ratio can be adjusted either 18 or 20
* Fits all major Sports Bikes
* MotoGP inspired piston assembly
* brake microswitch included
* Forged aluminum body
* Hard anodized finish
* Fitting instructions
Brembo radial master cylinder was the product which affected the braking system world in the last ten years. Designed for racing usage, during the years it became more and more appreciated also for the Supersport bikes and sometime for naked too, just remaining a product absolutely of racing nature, still present nowadays in MotoGP.
The structural radial scheme also allows to project a master cylinder with the aim to implement the hydraulic and mechanical ratios so as to improve the performance of the product. Up today, for twin disc systems, two models of master cylinders were available: 19 x 18 and 19 x 20. The choice between these two models was due to the different feeling that each of them gives to the rider: the 19 x 18 more adjustable, with a working stroke slightly higher than the 19x20, the 19 x 20 more aggressive.
Now, after more than 10 years of absolute leadership, this product has been updated by a series of technical relevant news, all coming from MotoGP, which led to the realization of the new racing radial master cylinder.
Reservoir mounting kit for RCS radial master cylinder. Can be used with any master cylinder that has a vertical split where the clamp mounts the master cylinder to the handlebar.
Kit Includes:
1 Complete Reservoir
1 Rubber bushing for reservoir
1 Mastercylinder Bracket
1 Machined Bolt with washer & nut for reservoir
1 Reservoir Tubing
2 Reservoir Tubing Clamps
2 Standoff Washers
1 Mastercylinder Bolt
Brembo 19x18 Radial Brake Master Cylinder RidersDiscount Riders Discount 0 Feb 17th, 2011 9:12 am
Brembo Radial Master Brake Cylinder beyote Superbikes 11 May 17th, 2009 11:40 pm
Brembo Forged Brake Master Cylinder Questions? boostedt0y Superbikes 7 Mar 27th, 2008 11:51 am
Brembo "GP" Radial Brake Master Cylinder: 19x18, $220 moto Motowheels 3 Feb 16th, 2007 7:54 pm
Brembo "GP" Radial Brake Master Cylinder XnewducX Ducati Motorcycle Chat 1 May 1st, 2006 2:34 am
