Corse Dynamics Ducati headlight for Monsters and Sport Classic - Ducati.ms - The Ultimate Ducati Forum
Old Mar 23rd, 2011, 6:42 pm   #1 (permalink)
Ducati.MS sponsor
moto's Avatar
Images: 30
Corse Dynamics Ducati headlight kit.
Fits all first generation Ducati Monsters and Sport Classics. The perfect solution for your Ducati. Kits includes:
· Black Powder-coated headlight bucket
· Clear 7 inch lens (uses H4 bulb)
· Billet black anodized bracket
· Hardware
· Instructions for installation
Easy install takes about 20 minutes. This kit gives you a more modern looking headlight lens while retain a vintage look with the headlight case. You will need to re-use your factory wiring for your headlight. The bracket mounts to your lower triple clamp where the factory mount currently mounts. You will remove the U-shaped bracket with mounts and headlamps. You will need to either remount your turnsignals somewhere or use a Oberon bar-end turnsignals kit.
Old Jun 12th, 2011, 8:26 pm   #2 (permalink)
Ive been thinking about doing something like this, although I wanted to use some old school billet side headlight mounts. Either way I would love to get rid of the stock headlight bracket. A few questions..
1. How did you mount the speedo?
2. Is it possible to get just a chrome headlight bucket? If so, and there is no way I can do this myself, I may look into getting this kit.
Thanks!
Adam
adamld83 is offline   Reply With Quote
Old Jun 12th, 2011, 9:03 pm   #3 (permalink)
Ducati.MS sponsor
moto's Avatar
Images: 30
HI Adam,
The gauges mounted on the SPEEDYMOTO Triple Clamp Set: Sport Classic. There are holes tapped in it already from SpeedyMoto for an exact fit.
The buckets are available in chrome.
-M
Corse Dynamics 4 spoke Clutch Cover moto Motowheels 0 Apr 2nd, 2010 11:44 am
Corse Dynamics Aluminum Sprocket Cover moto Motowheels 0 Mar 26th, 2010 12:22 am
Speedymoto vs Corse Dynamics Clutch Kit mstates Superbikes 1 Mar 16th, 2010 2:08 pm
Sport Classic Headlight Protectors PAKBIKES JC/PAK Bikes 0 Sep 30th, 2009 9:18 am
twin headlight for sport classic juannyducaty Sport Classic 3 Jan 22nd, 2008 7:47 am
